EMS 240mm for 2.0 TDI 16V BKD: Original?
Deus Violentia
Post21-04-2011, 19:39    Subject: EMS 240mm for 2.0 TDI 16V BKD: Original? Quote
In short: Is there a 240mm electronic motor shortening (EMS) system for VW/Audi that is compatible with the power output of a 2.0 TDI engine?
BKD GRF
AHF EBF
Translated on 21-08-2026, 11:32.
Fab176
Karma: +1 / -1   Thank you, like it!
2000 Volkswagen Golf
Post22-04-2011, 10:50    Subject: EMS 240mm for 2.0 TDI 16V BKD: Original? Quote
I have a 240mm Sachs EMS clutch installed on my 2.0 TDI engine. Sachs also offers a more powerful clutch that is designed to fit it. However, I cannot determine whether or not this meets the criteria of being "original" equipment. It's definitely not from SPEC or a similar brand.
Fabian.
VW Golf 4 TDI 4motion
Translated on 21-08-2026, 11:33.
Deus Violentia
Post27-04-2011, 10:34    Subject: EMS 240mm for 2.0 TDI 16V BKD: Original? Quote
Do you use a sprung or rigid friction disc?
Question for everyone: Is applying "starr" (presumably referring to a specific setting or mode) always considered detrimental to the transmission and drivetrain, or only when you disable the brain and engage in full-power, binary coupling?
BKD GRF
AHF EBF
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Motor Running" Signal on 1Z-STG? Diesel Engine Technology
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts "AdBlue error message, but fault memory is empty." Diesel Engine Technology
