exciter
Registered VCDS User
11-03-2011, 13:29 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Hello.
My car is shaking when idling, and it doesn't always start well when it's warm.
Now, while logging data from the MWB4, I noticed that when it experiences more intense vibrations, the injection timing shifts to 6-7° BTDC (Before Top Dead Center).
Ist das normal oder kann die Pumpe einen weghabe, bzw. kommt das Signal irgendwo anders her? NHG etc...
Engine: 2.5 V6 TDI, engine code: BDG, mileage: 120,000 km.
Best regards, Steffen.
| Description: |
| MWB4, Motor auf Betriebstemperatur. |
 Download |
| File name: |
test.csv |
| File size: |
8.19 KB |
| Downloaded: |
1030 times |
Translated on 29-08-2026, 4:30.
schrauber2904
17-03-2011, 19:37 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Are you in the measurement block or the basic settings? If the engine is at least 80 degrees Celsius, you can check the pump setting in the basic settings, for example, after a timing belt replacement. The value should then be 2° after top dead center (OT), plus or minus 1.5°.
Translated on 29-08-2026, 4:31.
exciter
17-03-2011, 21:33 Subject: TDI Injector Timing Issues: V6 BDG Engine |
It's in the main menu, not in the default settings.
In its default setting, it runs perfectly smoothly, with no stuttering or glitches, and remains stable up to an angle of 6-7 degrees.
When I exit the basic settings mode, the RPM drops to 740, it starts to sputter again, and I experience those jumps of 6-7 degrees.
Do the actual values come from the needle displacement sensor?
Herbert Profi-Schrauber
17-03-2011, 21:52 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Just to be sure - is the setpoint constant, while the actual value "jumps"? What does the duty cycle do?
Translated on 29-08-2026, 4:32.
exciter
17-03-2011, 21:56 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Yes, the target value remains at 2.2-2.4, but the actual value shows 1.8-2°, while intermittently displaying a value of 6.6°.
Seen in this log:
/download.php?id=5489
Translated on 29-08-2026, 4:33.
17-03-2011, 22:06 Subject: TDI Injector Timing Issues: V6 BDG Engine |
You can't read anything properly here. You have to save the file as a CSV and leave it unchanged.
But to get to the core of it - what does the duty cycle do?
"vg"
This is a common abbreviation for "very good" in German. It is often used in online forums and chat rooms.
Translated on 29-08-2026, 4:34.
exciter
17-03-2011, 22:17 Subject: TDI Injector Timing Issues: V6 BDG Engine |
It always stays at 100.2.
Even if you go all the way to the top of my thread to download?
I converted the file using the log converter.
Everything is working perfectly in my Excel.
17-03-2011, 23:19 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Quote: | | This always remains at 100.2 | , which means that the ECB's regulation in the LL (Liquidity Lending Facility) is already at its maximum limit.
Please don't take offense to my questions. Are you sure you have the correct calibration map selected? Have you completed the actuator diagnosis?
To determine the actual EZP (likely referring to a specific parameter), the signal from the NHG (likely a sensor or component) is used. The MSG (likely a controller or module) regulates the system to the target value.
"vg"
Translated on 29-08-2026, 4:35.
17-03-2011, 23:25 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Subtract the NHG (natural health group) amount and observe the resulting value.
Translated on 29-08-2026, 4:36.
Profile PM Garage |
exciter
18-03-2011, 13:10 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Hello Herbert,
I'm sure of that.
I start VCDS, then go to "Engine Electronics," "Measuring Blocks," and then select "004."
What happened again?
Engine warmed up, water temperature 90°C.
Please provide the text you would like me to translate from German to English. I will then provide the translation without any explanations.
I haven't done anything to the pump yet, or adjusted anything.
edit: I did another one. Once it's warmed up and the RPM settles down to the idle speed after reaching a higher RPM, the duty cycle goes back to 100.2.
| Description: |
| Tastverhältnis, Motor warm, nach höherer Drehzahl. |
 Download |
| File name: |
tastung.csv |
| File size: |
6.38 KB |
| Downloaded: |
390 times |
| Description: |
| Tastverhältnis. Motor warm, Dauerhaft im Leerlauf. |
 Download |
| File name: |
mwb4neu.csv |
| File size: |
3.66 KB |
| Downloaded: |
360 times |
Translated on 29-08-2026, 4:37.
exciter
20-03-2011, 20:58 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Good evening.
Can someone tell me if it's normal for the duty cycle to be 100.2% when the engine is idling, or is something defective or incorrectly adjusted?
Translated on 29-08-2026, 4:38.
Joined: 04/12/2002 Posts: 18086 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
20-03-2011, 21:25 Subject: TDI Injector Timing Issues: V6 BDG Engine |
It's not normal to have a permanently displayed 100% traction value. Please check what TDI-GTI-4-Motion wrote.
Profile PM WWW Garage |
exciter
20-03-2011, 23:26 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Okay, I'll report back tomorrow.
Have a nice evening.
Translated on 29-08-2026, 4:39.
exciter
21-03-2011, 19:27 Subject: TDI Injector Timing Issues: V6 BDG Engine |
Okay, here I am again.
I disconnected the needle lifter while the engine was still warm.
The duty cycle remained at 100.2% in this case as well. It settles back to that value after 5-10 seconds when the engine is idling.
In the end, I reconnected the NHG, and after that, the actual values started showing the -6.6° jumps again.
Then I created another log during the trip.
"Sometimes, you also get some strange values, right?"
At 57.12 seconds, the target value is -4.6, the actual value is 0.6, and the threshold is 100.2.
73.16s Target -13.8, Actual 0.2
Strange...
Translated on 29-08-2026, 4:40.
slow-moe Schrauber
21-03-2011, 21:05 Subject: TDI Injector Timing Issues: V6 BDG Engine |
The current air-fuel ratio indicates to me that the ESP (Electronic Spark Advance) is misadjusted. If you advance the timing, it should improve.
The jerks, on the other hand, could be caused by a stuck injection control valve piston. Unfortunately, the only solution in this case is to replace or repair the pump.
Translated on 29-08-2026, 4:41.
exciter
21-03-2011, 21:13 Subject: TDI Injector Timing Issues: V6 BDG Engine |
But shouldn't the default setting tell me that the values are outside the tolerance range?
"So, it won't be the NHG (National Health Insurance) with those fluctuating values, right?"
The pump was refurbished in November 2010.
It was a service technician from Bosch.
Translated on 29-08-2026, 4:42.
