p.schneckenburger Guest
10-05-2002, 21:16 Subject: Timing Belt Failure: Engine Damage Causes |
Engine damage.
hello,
'The timing belt on my Caravelle TDI 2.5L 75 kW broke today, likely causing engine damage. Does anyone have experience with reputable engine replacement manufacturers and can recommend any?'
Perhaps we could also incorporate something stronger this time. I would be grateful for any tips on that!
Peter.
Translated on 30-10-2026, 9:37.
D. Guest
13-05-2002, 7:40 Subject: Timing Belt Failure: Engine Damage Causes |
Hello!
A friend of mine had a timing belt failure on his Caravelle or Multivan TDI, even though the mileage for the scheduled replacement hadn't been reached yet.
I mean that VW has taken over the complete labor costs associated with a replacement machine.
Get in touch with your 'VAG partner.'
Just a tip.
Best regards, D.
Translated on 30-10-2026, 9:38.
Thomas K. Guest
13-05-2002, 11:43 Subject: Affected Victims: Multiple Cases Reported |
Take a look at uli-joos' website. He also experienced a timing belt failure on his T4 and, I believe, filed a complaint with VW along with several other affected owners.
Translated on 30-10-2026, 9:39.
Ingo Guest
14-05-2002, 16:30 Subject: Timing Belt Failure: Engine Damage Causes |
It seems to be a common problem with VW vehicles. My uncle's company-owned T4 had its belt break at 49,000 km, and since then, there has been a lawsuit against VW.
The best part is, the T4 just came out of the workshop! Unfortunately, the service plan states that the timing belt will only be checked at 90,000 km.
'But that's not the only problem with the T4. My uncle has two, and both need to go to the workshop regularly; something is constantly breaking on both vans. That's why he bought two Peugeot Boxers instead; he's had them for years and they haven't given him any problems. He doesn't want to buy another VW anymore, which I can definitely understand, even though I'm a VW fan.'
Translated on 30-10-2026, 9:40.
