TDI vs. PD Injector: A Comparison
vwSchrauber
Post24-06-2011, 13:32    Subject: TDI vs. PD Injector: A Comparison Quote
After having both items right next to each other in the workshop, I took a closer look and compared them.
Kolbenmasse (incl. Bolt:
AFN: 777g
AUY: 789g
Bolt: Approximately 4g lighter when used with the PD system.
Bolt diameter: the same, but different design (tapered material recesses at the ends).
Compression height: equal.
Piston guide (piston liner): approximately 3mm shorter in the PD model.
Mulde: apparently identical.
Connecting rod bearings: identical except for the locating features.
Connecting rod: The PD engine (as is generally known) uses trapezoidal connecting rods, which means that pistons and connecting rods can only be used in pairs.
I find it interesting that the PD piston, despite the cooling channel and shorter guide, is heavier icon_confused.gif.
Translated on 05-10-2026, 9:08.
fantomas
Karma: +5 / -1   Thank you, like it!
Post24-06-2011, 14:31    Subject: TDI vs. PD Injector: A Comparison Quote
Yes, I can confirm that to a certain extent.
As further notes:
-The valve pockets are deeper in the AFN engine.
-The piston bowl is offset (in the Y-direction) in the AUY engine.
-The AUY had brass-made hub bushings.
Translated on 05-10-2026, 9:10.
vwSchrauber
Post24-06-2011, 14:52    Subject: TDI vs. PD Injector: A Comparison Quote
The valve pockets have deeper recesses
in the AFN.
I'll measure it again shortly.
The piston groove in the AUY engine is offset (in the Y direction)
Does the AFN also have a two-valve engine?
The AUY used brass hub bushings.
"Does the AFN engine also have it? I'm not sure about the AAZ engine. The older TD engines (1.6L, 2.0L R5, 2.4L R6) definitely don't have it."
Translated on 05-10-2026, 9:11.
fantomas
Post24-06-2011, 15:50    Subject: TDI vs. PD Injector: A Comparison Quote
I don't know if the AFN also has it, but I'm not sure about the AAZ. The older TDs (1.6l, 2.0l R5, 2.4l R6) definitely don't have it.
I understand it like this: The pistons from the AFN engine (base Golf 3) do not have bushings, while the pistons from the AHF engine do have these bushings.
Does the AFN also have it, although it's a two-valve engine?
The offset refers to the displacement in the Y-direction. For the AUY, this offset is approximately 1mm, while it is not present for the AFN. The X-axis offset is the same for both, at approximately 7mm.
 Konbenverleich AFN AUY
 File size:  16.06 KB
 Viewed:  1511 times
Translated on 05-10-2026, 9:13.
Held467
Post24-06-2011, 16:49    Subject: TDI vs. PD Injector: A Comparison Quote
There are many different types of AFN connectors available, some with a socket and some without, and the specific type depends on the year of manufacture.
Translated on 05-10-2026, 9:14.
