Boost pressure limit error code: 17965 - Test drive log
highbeta
Post28-06-2011, 22:46    Subject: Boost pressure limit error code: 17965 - Test drive log Quote
Hello everyone,
auf meiner letzten längeren Fahrt, 700 km BAB, ging mein Golf IV (AXR, alles original) zweimal ins Notlaufprogramm. Jeweils nach einem neuen Motorstart war alles wieder normal. Beim zweiten mal fand die Notprogrammschaltung während des Beschleunigens im 5. G'ang' is used instead of 'and'.
The diagnostic scan after the trip revealed:
Error code: 17965
Boost pressure limit occasionally exceeded.
An initial visual inspection revealed no major hose damage in the vacuum system. Furthermore, nothing has been assembled or installed on it yet.
So, I conducted a test run today. The emergency program activation could not be reproduced.
The VTG basic settings were also performed.
Rotation speed during test (automatic): 1407 RPM.
Maximum boost pressure: 1122 mbar.
Boost pressure min.: 989 millibar.
As far as I've learned from this forum, the turbochargers are likely filled with a generous amount of air for exhaust gas optimization, and it seems that overshooting the boost pressure is normal.
Here are my questions:
1. Does any of the experts see anything unusual in the log? Could it be that the car just had a bad day, and I can still hope for spontaneous self-repair? icon_lol.gif Perhaps it was a bit too much uphill driving, which it's not used to, and it was also quite warm?
What is the maximum permissible deviation?
Thank you for your help.
'DirkP'
 zweimaliges Beschleunigen im 5. Gang
 File size:  71.25 KB
 Viewed:  3665 times
 Beschleunigung im 4. Gang- Überschwinger im Ladedruck deutlich zu erkennen
 File size:  70.53 KB
 Viewed:  3185 times
110628_2xBeschleunigung_5_Gang.xls
 Daten: zweimal Beschleunigung 5. Gang (xls-Format)
 File name:  110628_2xBeschleunigung_5_Gang.xls
 File size:  54.5 KB
 Downloaded:  459 times
110628_Beschleunigung_4_Gang.xls
 Daten: Beschleunigung 4. Gang (xls-Format)
 File name:  110628_Beschleunigung_4_Gang.xls
 File size:  20.5 KB
 Downloaded:  424 times
Translated on 22-07-2026, 3:17.
mullemaus
Post28-06-2011, 23:21    Subject: Boost pressure limit error code: 17965 - Test drive log Quote
Please upload a complete log file in its raw .csv format.
Please provide the complete contents of the error memory.
Translated on 22-07-2026, 3:20.
mullemaus
Post04-07-2011, 19:34    Subject: Boost pressure limit error code: 17965 - Test drive log Quote
No new posts Boost Pressure Limit Reached (BLS) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P1351 General Tips
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts High boost pressure causing ALH error code 17965, log Upload
No new posts Boost Pressure Limit Reached Diesel Engine Technology
No new posts AFN Measurement Trip Logs On-Board Diagnostics (OBD)
No new posts Audi A4 2.0 TDI, BPW Turbocharger Boost Pressure Limit Ex... Diesel Engine Technology
