2.5 TDI BDG: Boost Surge Explained
Go to page: 1, 2  Next
B6BDG
Registered VCDS User
Post07-05-2011, 14:19    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
habe mal den Ladedruckaufbau gelogged (3. Gang Vollgas), weil meine VTG etwas schwergängig zu sein scheint. Der Ladedruck erreicht zwischenzeitlich fast 2.6 Bar. Is that still okay?
The engine is a 2.5 TDI BDG with 140,000 km (approximately 87,000 miles).
Thank you very much in advance.
 File size:  138.94 KB
 Viewed:  4404 times
Translated on 22-08-2026, 12:27.
mullemaus
Post07-05-2011, 18:34    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
Post10-05-2011, 19:03    Subject: 2.5 TDI BDG: Boost Surge Explained Translating...
[Translating...]
VCDS Lite...
mullemaus
Post10-05-2011, 21:17    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
The car reminds me a lot of my experience 'back then'. icon_rolleyes.gif Some 2.5V6 engines have this issue. icon_confused.gif Even without the front/main catalytic converter, it didn't show any improvement. icon_lol.gif Manufacturing tolerances. icon_lol.gif icon_wink.gif }
Translated on 22-08-2026, 12:28.
Post11-05-2011, 8:07    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
Is the dataset up-to-date? Theoretically, you can check if the VTG (variable turbine geometry) is functioning by disconnecting the vacuum pump, but I don't know if it's easy to access that part on this engine.
Post11-05-2011, 8:25    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
dieselschrauber wrote:
...honestly, I'm not sure if you can easily get to that area on the engine.
Translated on 22-08-2026, 12:29.
B6BDG
Post11-05-2011, 15:17    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
How can I tell if the dataset is up-to-date?
I tried testing the VTG with a syringe. I couldn't detect any stiffness. The rod followed the movement of the syringe plunger directly. However, I'm not sure if I pushed the 60mL syringe all the way in; it probably didn't reach the very end. The vacuum seems to be okay (-700 mBar). Could it also be the N75 valve? Unfortunately, the actuator diagnosis switches abruptly between 100% and 0%, making it difficult to test properly.
I've found another peculiar entry in the log. It seems like the boost pressure regulation is oscillating correctly here. This might have been during a thrust phase. Therefore, I'm not sure if it means anything significant.
 File size:  133.05 KB
 Viewed:  3506 times
Translated on 22-08-2026, 12:30.
Post13-05-2011, 19:34    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
By posting the VCDS control unit information and having someone check if there's an update available.
Translated on 22-08-2026, 12:31.
B6BDG
Post15-05-2011, 12:04    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
Can it be recognized from here?
Address 01: Engine Labels: 059-907-401-AKE.LBL
Controller: 8E0 907 401 T
Component: 2.5L V6 TDI G000SG 0004
Coding: 02002
Shop #: WSC 63251
VCID: 361F603F0149
00006059 130 106KC318_1.V14834812390
No fault code found.
Readiness: Not applicable.
Translated on 22-08-2026, 12:32.
Post15-05-2011, 12:36    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
Yes, dataset for VAG part number: 8E0 907 401 T, software version 0004.
Translated on 22-08-2026, 12:34.
B6BDG
Post15-05-2011, 13:23    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
This is probably not the latest version. But is there any way to update it other than installing a new control unit?
Post15-05-2011, 14:24    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
Your engine control unit can be normally updated via OBD by a qualified mechanic or tuner who has a current, compatible data set.
B6BDG
Post15-05-2011, 16:44    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
Are you sure? I always find information stating that the 2.5 TDI engine control unit cannot be reflashed, and the technical service bulletins (TPIs) consistently recommend replacing the control unit as a solution.
Translated on 22-08-2026, 12:35.
Post15-05-2011, 18:12    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
If you have access to the TPIs, why don't you simply look for the answer yourself regarding your problem? icon_rolleyes.gif
It's logically flashable; it's an EDC15VM+ unit.
B6BDG
Post15-05-2011, 18:49    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
Regarding this specific problem, I haven't found anything concrete. However, with other issues (e.g., idling problems) in the BDG engine, the control unit is sometimes replaced due to a software update.
Translated on 22-08-2026, 12:36.
Post15-05-2011, 19:22    Subject: 2.5 TDI BDG: Boost Surge Explained Quote
Okay, it's possible that the control unit has a fundamental hardware problem that cannot be fixed by changing the software.
I can't really think of any specific reason related to the boost pressure control for that.
Just try replacing the N75 valve; it's not expensive and rarely causes any issues.
Translated on 22-08-2026, 12:37.
No new posts Boost surge On-Board Diagnostics (OBD)
No new posts Boost Overrun: Causes & Solutions On-Board Diagnostics (OBD)
No new posts Boost overrun V6 TDI BDG Upload
No new posts 1.9 TDI BLS: Boost Surge Explained Diesel Engine Technology
