Cruise Control Wiring: No GRA Switch Needed
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
polo2f
Post15-10-2013, 9:57    Subject: Cruise Control Wiring: No GRA Switch Needed Quote
Hello.
Ich möchte in einem 2001er Golf 4 AJM die GRA ohne serienmäßigen Schalter anschließen. Könnt ihr mir bitte sagen, ob die Belegung so stimmt? Danke
10-pin connector on the GRA switch:
Pin 4.7 on terminal block 15.
Connect pin 2 to terminal 15 via a normally closed button; SET function.
Connect pin 3 to terminal 15 via a normally closed button (NC), RES.
Connect pin 5 to terminal 15 via a normally open button; reset function.
Paul.
Translated on 24-07-2026, 4:56.
Post15-10-2013, 14:05    Subject: Cruise Control Wiring: No GRA Switch Needed Quote
It might work icon_wink.gif. You can check the functions using VCDS through the measuring blocks icon_wink.gif.
Translated on 24-07-2026, 4:57.
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tempomat-Einbau-Probleme Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation: Citroen C4 2.5 TDI Diesel Engine Technology
No new posts Do not connect the trailer hitch to the CAN bus. Electrical Systems, Vehicle Electronics, Multimedia
No new posts Universal Oxygen Sensor: Installation & Wiring Guide Gasoline Engine Technology
No new posts Neue Steuergeräte an die K-Leitung anschließen On-Board Diagnostics (OBD)
