Auxiliary Heater Problems: Troubleshooting Guide
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Touran2
Registered VCDS User
Post16-10-2011, 8:50    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Hello, I had the auxiliary heater upgraded to a full-fledged heater at a VW dealership 4 years ago.
Now it's broken. I had it replaced, and they need to re-pair it.
What's new is that the car's diagnostic scan now shows a "7D" code, which indicates an issue with the auxiliary heating system.
The people at Bosch who installed the heating system probably don't know what they're doing!
I just checked and saw that the heater is listed under "equipment for vehicles under 18" and is being identified as a supplemental heater.
Now, all they have to do is install the new software!
Or.
Here's my scan.
Can you help me with that?
auto scan.txt
 File name:  auto scan.txt
 File size:  10.41 KB
 Downloaded:  2062 times
Translated on 14-09-2026, 21:54.
voodoo
Post16-10-2011, 10:20    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Okay, let's write this down again.
1. The vehicle was originally equipped with a Webasto auxiliary heater from the factory.
2. You had the auxiliary heater upgraded to a full-fledged heater via a software update purchased from VW.
3. Bosch has now installed a replacement heater core.
Is that correct?
If so, unfortunately, it will be expensive again.
The SW update of a Webasto auxiliary heater to a stand heater is performed using a license dongle.
This dongle can be used exactly once. After that, it is consumed and only suitable for recycling.
The dongle costs almost €400 and is part of an upgrade kit.
The dongle is not sold separately.
So, I would go to Bosch and demand that they install a stand-alone heater for you.
Of course, you should have the VW invoice with you to prove that the defective old device actually received an upgrade.
Translated on 14-09-2026, 21:56.
Touran2
Post16-10-2011, 10:45    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Hello, yes, so far, everything is correct.
Pre-heater.
Upgraded at VW 4 years ago.
3. Replacement of the Bosch heating system as a supplementary heater.
4. The dongle is present, but they cannot install it!
"So, the problem, according to Bosch, is that they can only upgrade the system if they have access to the auxiliary heater."
What I can't understand is that they should have access, see point 18... The function /7 D Zuheitzer is not correct!
If I'm not mistaken, there shouldn't have been a 7D heater code on my car's diagnostic scan before.
Bosch stated that the gateway was not communicating with the auxiliary heater.
They want to explain to the Touran that it is a pre-heater. However, the Touran already knows this, as it can be seen on setting 18, under the "Component: Pre-heater" section.
P.S. The auxiliary heater is also working as it should. It turns on at temperatures above +5°C, and can be deactivated using the "Econ" mode.
They just didn't explain how they could get the software to run on the older device.
Translated on 14-09-2026, 21:59.
voodoo
Post16-10-2011, 15:11    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Is the auxiliary heater connected via a Webasto USB adapter?
If you haven't installed a wireless remote control, the message 'W-Bus communication error' is normal.
Can be ignored.
The update can be installed by anyone, so you don't need to take it to a workshop.
I think I'm going to switch to a different Bosch workshop, especially since I don't understand why they didn't just install a standing heater in the first place!
'You could have saved the 400 euros for the upgrade!'
Translated on 14-09-2026, 22:01.
Touran2
Post16-10-2011, 15:51    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Hi, I'm not sure what problem they're having with the software update.
And Webasto provided the software free of charge.
If you look at my car's diagnostic scan, what would you say about it?
"That 7D control unit is wrong, isn't it?"
Can they not install the software update via the in-car entertainment system?
And VCDS doesn't work for flashing the software, as I was informed by VCDS.
Translated on 14-09-2026, 22:02.
Post16-10-2011, 16:28    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
I would like to try disabling the auxiliary heater in the gateway (address 19) and then address the error messages in the control unit address 18 (http://www.obd-info.de).).
Possibly, the air conditioning system and the vehicle's onboard network control unit are also incorrectly coded (set to auxiliary heater mode). So, clear all the error codes and see which ones reappear.
Translated on 14-09-2026, 22:03.
Touran2
Post16-10-2011, 18:08    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Hello, I have a question about this upgrade.
How should this be implemented? Should the software automatically detect the heating system, or does it need to be configured manually?
Example 18: Auxiliary heater installed, and we're ready to go. Or, how should I envision this upgrade?
Since I'm not yet clear on why Bosch is serving the "Zuheitzer 7" with a specific encoding in the gateway.
Since the heating system is already operating below 18 degrees Celsius, the auxiliary heater component would be activated.
Thank you.
P.S. If I want to perform a long encoding process and then click "close," I get error 31.
I don't have the login code. Where can I get it? My VCDS doesn't show it to me with a pop-up.
Or am I doing something wrong? Otherwise, I would have tried them out myself over the weekend.
Translated on 14-09-2026, 22:05.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post17-10-2011, 6:16    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
The Webasto upgrade kit includes all the necessary parts, both hardware and software.
First, you need to check the software version in the control unit of the auxiliary heater using VCDS. If it is below version 13.12, you must first update the auxiliary heater software to version 13.12 or higher. However, this cannot be done with VCDS. Then, clear all errors. If there are serious errors stored or the heating unit is locked, it must first be repaired. Fortunately, this probably doesn't apply to you.
Imagine this: The adapter cable, where this dongle is inserted, must be directly connected to the heating system. And it should be connected not through the car's OBD socket, but via an (included) adapter to the connector of the control unit, whether it's a clock or a remote control.
Okay, so you connect one side of the watch adapter to the watch and the other side to the USB port on the computer. Then, insert the Webasto CD and start the program "upgrade.exe". And that's it.
After that, you can use VCDS to desensitize, for example, the interior monitoring system by 50%, if available. Then, you can perform another system scan.
These upgrade kits actually come with a detailed instruction manual.
Passat Variant BGW 2005
Translated on 14-09-2026, 22:08.
Touran2
Post17-10-2011, 9:19    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Thank you for the detailed report.
The problem, according to Webasto, is that the device cannot connect to the heater via the 1533 interface using the dongle, and an error message is always displayed.
It's likely that the auxiliary heater needs to be coded in the vehicle's control unit (possibly module 17) by a VW technician because the Webasto specialists are unable to resolve the issue.
The Bosch technician just called me and said that he tried everything as you described, and he's still getting the same error.
He wants to go to the VW dealership today, as mentioned, with the Touran to have the coding done.
And Webasto recommended installing the Gateway 7D coding.
Thank you.
Translated on 14-09-2026, 22:10.
Steffen W
Post17-10-2011, 15:44    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
It's okay to first reset everything to the original state, i.e., the auxiliary heating mode, because the upgrade software also expects this state.
Then there's another point: Is the heating system software version 13.12 or higher installed?
Is the dongle really okay?
Touran2 wrote:
always displays an error!
Which one?
Translated on 14-09-2026, 22:11.
Touran2
Okay, they just called me and said they unfortunately can't install the software.
There is no connection established with the heating system. VW's online support also doesn't have a solution, and they say that the CAN bus line is likely not communicating.
I could really use a good tip right now.
Thank you.
Translated on 14-09-2026, 22:12.
Touran2
Post18-10-2011, 10:11    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Hello, I need some help with tax code 19. Apparently, Bosch hasn't been able to decode the "7d" sequence.
I'm using the full version of the software and want to modify the long code, but I don't have the LOCIN code. Can anyone send it to me?
Or...
Thank you.
Saturday, October 15, 2011, 1:28:20 PM.
VCDS Version: DRV 10.6.4
Data as of: 20110418.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 55 56 62 72 76 77
7D
Vehicle Identification Number: WVGZZZ1TZ4W146540
Mileage: 221,250 km
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-inch heater -- Status: Error 1010.
19-pin diagnostic interface -- Status: Error 0010.
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking assist -- Status: OK 0000
77-Phone -- Status: OK 0000
7D Heater -- Status: unreachable 1100.
Address 01: Engine Control Module
Label file: DRV\03G-906-016-BKD.lbl
Part number SW: 03G 906 016 EH, HW: 028 101 178 6.
Part: R4 2.0L EDC G000SG 7214
Revision: 12345678 Serial number: VWZ7Z0D9424319
Encoding: 0000072
Operating number: WSC 76082 146 84422
VCID: 6DE9E2340D01
No error codes found.
Readiness: 0 0 1 1 1
Address 03: Brake Electronics
Label file: DRV\1K0-907-379-MK60-F.lbl
Part number: 1K0 907 379 K
Part: ESP FRONT MK60 0103
Coding: 0006854
Operating number: WSC 76210 146 95128
VCID: 3A4319680CCF
Address 08: Climate Control/Heating. Label file: DRV\1K0-907-044.lbl
Part number: 1K0 907 044 L
Component: Climatronic PQ35 061 0201
Operating Number: WSC 00000 000 00000
VCID: 30573B40DAB3
"One error found:"
01207 - Control unit for auxiliary heater (J364)
004 - No signal/communication.
Address 09: Central Electronics
Label file: DRV\3C0-937-049-23-H.lbl
Part number SW: 1K0 937 049 L. Hardware: 1K0 937 049 L*.
Component: On-board network SG 1.0 H30 0701.
Revision: 00030000 Serial Number: 00000000619313
Encoding: 038B8F020004100000120C000000000000
VCID: 3847036032C3
Part number: 1T0 955 119 C
Part: Wiper VW358 012 0401.
Encoding: 00065493
Operating number: WSC 00000
"One error found:"
00483 - Control unit for auxiliary heater.
Address 15: Airbag
Label file: DRV\1T0-909-605.lbl
Part number SW: 1T0 909 605 Part number HW: 1T0 909 605
Part number: 05 AIRBAG VW62 0506 2112
Encoding: 0012341
Operating number: WSC 01324 785 00200
VCID: F2D37148943F
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 A, Hardware: 1K0 953 549 A.
Component: Steering column module 012 0030.
Encoding: 0000042
VCID: 30573B40DAB3
Address 17: Control panel module
Label file: DRV\1K0-920-xxx-17.lbl
Part number: 1T0 920 860 G
Component: COMBINATION INSTRUMENT VDD 3354
Encoding: 0007101
Operating number: WSC 76210 146 51344
VCID: 35590A5425D1
Address 18: Auxiliary heater
Label file: DRV\1K0-815-071.lbl
Part number: 1K0 815 071 AD
Component: Auxiliary heater 022 3907
Revision: 00022000 Serial number: 09020188000000
Encoding: 0011012
Operating number: WSC 75671 146 100898.
VCID: 67E5901C2FFD
2 error codes found:
02456 - Line filling.
005 - No or incorrect initial setup/adjustment.
Environmental conditions:
Error status: 01100101
Error priority: 7
Error frequency: 1.
Lost Count: 170
Mileage: 221,253 km
Time: 0.
01299 - Diagnostic interface for data bus (J533).
Error status: 01100100
Error priority: 6
Error frequency: 1.
Lost Count: 170
Mileage: 221,253 km
Time: 0.
Address 19: Diagnostic interface
Label file: DRV\1K0-907-530.lbl
Part number SW: 1K0 907 530 C, HW: 1K0 907 951.
Component: Gateway H08 0080
Revision: 08 Serial Number: 260010422502B9
Encoding: 7D3F1FC0078002 (new)
7D3F17C0078002 (old)
VCID: 2765D01CEF7D
Error priority: 2
Error frequency: 2.
Lost Count: 170
Mileage: 221,253 km
Time: 0.
Date: 2000.00.00
Time: 13:19:37
004 - No signal/communication - Intermittent.
Error status: 00100100
Error priority: 2
Error frequency: 1.
Lost Count: 210
Mileage: 221,253 km
Time: 0.
Date: 2000.00.00
Time: 13:25:48
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.lbl
Component: IMMO 3354
VCID: 35590A5425D1
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MIN1.lbl
Part number: 1T0 959 701.
Component: Door control unit 09 0127.
Encoding: 0000116
VCID: F4DF7750EE2B
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x-44.clb
Part number: 1K1 909 144 F
Component: EPS_ZFLS, Size 0, Part Number: 1301.
VCID: 2E6B2538C087
Address 46: Comfort System
Label file: DRV\1K0-959-433-MIN.clb
Part number: 1K0 959 433 C
Component: KSG 0201
Encoding: 00E802087F2D8404084F0100
VCID: 30573B40DAB3
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MIN1.lbl
Part number: 1T0 959 702.
Encoding: 0000116
VCID: F5D94A54E551
Address 55: Headlight range adjustment.
Label file: DRV\1T0-907-357.lbl
Part number: 1T0 907 357.
Component: Dynamic LWR 0002.
Encoding: 0000001
VCID: F4DF7750EE2B
Address 56: Radio
Label file: DRV\1K0-035-1xx-56.lbl
Part number: 1K0 035 186 J
Component: Radio GR0 0014
Revision: 0001002S Serial Number: VWZ2Z2D1123892
Encoding: 0040400
VCID: 2D692234CD81
Address 62: Door electric, left/right.
Label file: DRV\1K0-959-703-GEN1.lbl
Part number: 1K0 959 703 B
Component: Door control unit 06 0201.
Encoding: 0000048
VCID: 2F55383CC78D
Address 72: Door electrical, high, right.
Label file: DRV\1K0-959-704-GEN1.lbl
Part number: 1K0 959 704 B
Encoding: 0000048
VCID: 30573B40DAB3
Address 76: Parking Assist
Label file: DRV\1K0-919-283.lbl
Part number: 1K0 919 283 A
Component: 02 Parking Assist System 0101
VCID: 2D692234CD81
Address 77: Telephone Label file: DRV\1K0-035-729-UNI.lbl
Part number: 1K0 035 729 B
Component: CIB PAH HW 112 SW 0194
Operating Number: WSC 00001 000 00000
VCID: 2867D320E263
Address 7D: Auxiliary heater.
unavailable
End.
Translated on 14-09-2026, 22:38.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post18-10-2011, 12:19    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Hello!
You don't need a login code for that.
You go into the control unit 19 and then click on "Parts List". There, you can add or remove checkmarks as you like. At least, that's how it works for me.
[VERKAUFT] Polo 6NF 1.4TDI (AMF) mit nachgerĂŒstetem DPF, STH+FFB, Bj. 2000, 222tkm
Translated on 14-09-2026, 23:05.
Touran2
Post18-10-2011, 12:56    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Okay, thanks, I'll try it out later.
Thank you.
I'm not yet sure why I can't access the heating system through the pre-selection interface (1533 cable) to install the software and turn it into a stand-alone heater.
Since the heating system was upgraded from a basic heater to a standing heater, the wiring is still the same as it was before.
The only thing that was different for me was that the Y-cable had an LED that indicated the power-on point, which I had to disconnect (cut). Otherwise, the pre-selection timer didn't work.
Could it be that I need to bypass this cable with a light bulb to restore the connection to its previous state?
But I also read something about swapping pin 1 and pin 2!
Translated on 14-09-2026, 23:06.
Touran2
Post19-10-2011, 9:13    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
Hello, the software is installed, but the remote control and pre-selection functions cannot start the heating, and I still need to test whether the auxiliary heating function works.
I still need some tips.
Thank you. Wednesday, October 19, 2011, 09:31:33:26452.
Vehicle type: 1K0
Mileage: 221,450 km
08-Climate control/heating unit -- Status: OK 0000
18-inch heater -- Status: Error 0010.
19-Diagnosis interface -- Status: OK 0000.
44-Steering assist -- Status: OK 0000
76-Parking Assist -- Status: OK 0000
Encoding: 0000072
VCID: 6DE9E2340D01
Readiness: 0 0 0 0 1 0
Coding: 0006854
VCID: 3A4319680CCF
VCID: 30573B40DAB3
VCID: 3847036032C3
Encoding: 00065493
"One error found:"
Address 15: Airbag
Encoding: 0012341
VCID: F2D37148943F
Encoding: 0000042
VCID: 30573B40DAB3
Encoding: 0007101
VCID: 35590A5425D1
Component: Portable heater 022 3907
Encoding: 0001012
Operating number: WSC 76210 146 10089
VCID: 67E5901C2FFD
Error priority: 7
Error frequency: 1.
Lost Count: 173
Mileage: 221,367 km
Time: 0.
Error priority: 6
Error frequency: 1.
Lost Count: 173
Mileage: 221,367 km
Time: 0.
Encoding: 7D3F17C0078002
VCID: 2765D01CEF7D
VCID: 35590A5425D1
Encoding: 0000116
VCID: F4DF7750EE2B
VCID: 2E6B2538C087
Component: KSG 0201
VCID: 30573B40DAB3
Encoding: 0000116
VCID: F5D94A54E551
Encoding: 0000001
VCID: F4DF7750EE2B
Address 56: Radio
Encoding: 0040400
VCID: 2D692234CD81
Encoding: 0000048
VCID: 2F55383CC78D
Encoding: 0000048
VCID: 30573B40DAB3
VCID: 2D692234CD81
VCID: 2867D320E263
End.
Translated on 14-09-2026, 23:30.
Post19-10-2011, 9:29    Subject: Auxiliary Heater Problems: Troubleshooting Guide Quote
005 - No or incorrect initial setting/adjustment.
Error priority: 7.
Error frequency: 1.
Lost Count: 173
Mileage: 221,367 km
Time: 0.
Error priority: 6.
Error frequency: 1.
Lost Count: 173
Mileage: 221,367 km
Time: 0
Translated on 14-09-2026, 23:54.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Heater Error 02085: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 7D Heater: What is it? On-Board Diagnostics (OBD)
No new posts Turn off auxiliary heater On-Board Diagnostics (OBD)
No new posts Touran, first registration 6/10, engine code BLS, auxilia... On-Board Diagnostics (OBD)
No new posts 7D - Auxiliary heater malfunction Electrical Systems, Vehicle Electronics, Multimedia
