AKE Power Loss: Causes and Solutions
Go to page: 1, 2  Next
Dieselmike
Post22-05-2011, 9:57    Subject: AKE Power Loss: Causes and Solutions Quote
Hello everyone,
After having already done the following things to my V6 conversion in my VW T3 in order to finally achieve full performance, and knowing the articles about it inside and out...
- Engine completely mechanically overhauled.
-All sensors replaced. (All values are plausible.)
- Turbocharger has been rebuilt.
- Vacuum system OK (tested with actuator test, V-pump).
- Printing system sealed.
- Electricity OK.
- Fuel supply OK.
- No noticeable exhaust emissions.
-AGR is to...
-'Throttle valve' removed.
.....I just wanted to get your opinions again before I replace the VP44 (ouch).
Behavior:
The car is running in limp mode, the turbocharger engages late, and the boost pressure is 0.4 bar at 3000 RPM in 3rd gear. The air mass is currently at a maximum of 480mg (compared to 400mg when stationary).
The car can be cautiously accelerated with partial throttle. When full throttle is applied, it goes into emergency mode 2 after a few seconds.
Error in the ECU (Engine Control Unit).
- Intake manifold pressure regulation differential below minimum threshold.
- Start of injection, pressure differential.
Questions:
'If I fully open the turbo using the vacuum pump, is it normal to only have 0.4 bar at 3000 RPM? (Could the new one also be defective?)'
Can a diagnostic scan of the VP44 fuel injection pump by Bosch reveal whether it needs to be replaced?
Thank you all very much.
Translated on 01-11-2026, 23:20.
Post22-05-2011, 15:10    Subject: AKE Power Loss: Causes and Solutions Quote
If I fully open the turbo using the vacuum pump, is it normal that I only have 0.4 bar at 3000 RPM?
If a significant amount of fuel is being injected, no. Be careful, the turbocharger might spin up too quickly for you to be able to remove the injector...
Common issue in many T3 conversions: Check the charge air temperature sensor, measurement block 7, in the engine control unit.
Translated on 01-11-2026, 23:23.
Dieselmike
Post22-05-2011, 16:32    Subject: AKE Power Loss: Causes and Solutions Quote
I drove the lifted loader 30km just to get a little bit of power.
Charge air temperature is at 60°C (at worst).
The only question I have now is: should I remove the charger first, or the pump first?
Translated on 01-11-2026, 23:24.
christians
Post23-05-2011, 18:22    Subject: AKE Power Loss: Causes and Solutions Quote
If the pump doesn't inject enough fuel, the turbocharger won't be able to do its job.
What still needs to be measured is the back pressure in the exhaust system after the turbocharger.
However, the pump failure is not related to the turbocharger pressure error. Therefore, there is a defect in the pump area.
Gruß Christian
Translated on 01-11-2026, 23:25.
Dieselmike
Post24-05-2011, 6:10    Subject: AKE Power Loss: Causes and Solutions Quote
Thank you for your support.
I will replace the pump (as soon as I get one), and here are the results.
post.
It would be interesting to find out if the pumps in a manual transmission are different from those in an automatic transmission. I've converted everything to a manual transmission except, possibly, the pump. (I think the Bosch hotline will be able to tell me.)
Perhaps someone can tell me if it's relevant to the engine power if the clutch pedal switch isn't working (is bypassed). The fact is, if it's constantly activated, the car shifts quite smoothly. If it's constantly deactivated, it tends to surge (which makes sense, because the pump continues to deliver pressure without interruption due to the missing 'torque cutoff').
...see you soon.
Translated on 01-11-2026, 23:26.
Post24-05-2011, 7:26    Subject: AKE Power Loss: Causes and Solutions Quote
Perhaps someone can tell me if it's relevant to the engine power if the clutch pedal switch doesn't engage (is bypassed).
It could be the cause of the limp mode.
I have converted everything to manual transmission....
Was the MSG also replaced or "converted" to a manual transmission? Wiring harness: MSG - Engine?
"vg" is an abbreviation for "very good". It is often used in online forums and chat rooms to express agreement or approval.
Translated on 01-11-2026, 23:28.
Post24-05-2011, 8:39    Subject: AKE Power Loss: Causes and Solutions Quote
Good question, but what about the brake pedal switch? What does the corresponding VCDS measuring block say?
The engine control unit definitely won't deliver any power if the "brake pedal is depressed."
Translated on 01-11-2026, 23:29.
Dieselmike
Post24-05-2011, 18:31    Subject: AKE Power Loss: Causes and Solutions Quote
Yes, I'm very familiar with that brake problem.
(When both brake lights are defective on a Golf 4, the engine will no longer start because the input to the control unit is connected to ground through them.) I experienced this issue during my AXR engine conversion.
The brake pedal switch is installed strictly according to regulations.
The error codes in the TCU are only 023F and 0550.
Translated on 01-11-2026, 23:30.
Dieselmike
Post02-06-2011, 9:29    Subject: AKE Power Loss: Causes and Solutions Quote
I have been trying hard to find a suitable replacement pump, but unfortunately, I haven't had any luck. The problem is finding a pump that contains the software compatible with my control unit (which is currently different). Do I need to go to Bosch or Audi with the data from my control unit to find out the part number of the correct pump?
By the way, the car occasionally ran perfectly for a whole day again (a feeling like Christmas after two years).
The fact is: It goes into 'limp mode' 2 exactly at 3000 RPM and 100 km/h in 4th gear. Before that, I can easily rev it up to 4500 RPM. Everything is very strange...
Is there a competent diesel service center nearby that could take a look at this vehicle?
I'M SO ANNOYED!
Translated on 01-11-2026, 23:31.
Post02-06-2011, 11:41    Subject: AKE Power Loss: Causes and Solutions Quote
Dieselmike wrote:
I have now been intensively looking for a suitable pump to replace, but unfortunately, I haven't found anything. The problem is finding a pump that contains the software that is compatible with my control unit (currently different). Do I now have to go to Bosch or Audi with the data from my control unit to find out the part number of the correct pump?
By the way, the car would occasionally run perfectly for a day or so (a feeling like Christmas after two years).
The fact is: It goes into "limp home" mode 2 exactly at 3000 RPM and 100 km/h in 4th gear. Before that, I can easily rev it up to 4500 RPM. Everything is very strange...
I'M SO SAD!!!!!!
Why is the box going into emergency mode? Please check the error memory. icon_idea.gif
Translated on 01-11-2026, 23:33.
Dieselmike
Post28-06-2011, 20:26    Subject: AKE Power Loss: Causes and Solutions Quote
I had my fuel injection pump (VP44) checked at the diesel center.
Result:
Fault in the track switch and control unit.
They say, 'It's not worth repairing.'
...and now what??? ...should I buy my four children new bikes with the remaining value?
I would be very grateful for a GOOD idea.
Translated on 01-11-2026, 23:34.
Post28-06-2011, 22:45    Subject: AKE Power Loss: Causes and Solutions Quote
Dieselmike wrote:
Error: Quantity control valve...
The VP44 does not have a quantity control valve.
Could it be that the solenoid valve is defective?
Please tell me exactly what the Dieselzentrum told you.
Translated on 01-11-2026, 23:35.
@udi
Post29-06-2011, 8:23    Subject: AKE Power Loss: Causes and Solutions Quote
That's actually quite simple...
I can help you further.
Specifically, regarding the Vp44 pump type.
You have a problem with the control unit. We can repair it and even offer a one-year warranty on it. If you send us the entire pump, we will check it for leaks and test all the electrical components. The control unit will be placed on a test bench and repaired. The cost for this is 430 euros. There is a one-year warranty.
Unfortunately, we will be on vacation starting next week.
I'm not sure if I'm allowed to advertise my website here.
http://dieselhilfe.de
What is the part number of the pump?
Is that 059 130 106 E?
Jörg
Translated on 01-11-2026, 23:36.
Dieselmike
Post29-06-2011, 12:11    Subject: AKE Power Loss: Causes and Solutions Quote
The signal box is working correctly.
He's not revealing the exact error codes.
It's definitely the quantity regulator (solenoid valve).
The control unit itself is not supposed to be repairable, as it contains a ceramic plate.
The pump delivered an excessive amount during the test.
The gentleman told me the repair would cost 1549 euros plus VAT.
Since the car starts perfectly and accelerates normally up to a certain point, I can't imagine that this is a mechanical defect.
I think the hardest part of this whole situation is finding someone you can trust. I'm going to have the pump opened and inspected now.
Thank you for your help. I will get back to you as soon as there is any new information.
Translated on 01-11-2026, 23:38.
@udi
Post29-06-2011, 12:51    Subject: AKE Power Loss: Causes and Solutions Quote
I know that feeling. Unfortunately, it's typical.
I don't need the exact error codes either, as they vary from testing device to testing device. Although you are entitled to them. After all, you are paying for them.
We can repair electronic control units. Bosch service centers, however, prefer to sell complete pumps.
We have several years of experience in this field.
However, I suspect the problem lies with the fuel injector. To check it, the fuel pump needs to be opened.
Do not open the pump randomly just to take a look!!!
Then you have an even bigger problem.
And absolutely do not remove the gear!
If you have the time, you can send us the pump. The repair will cost a maximum of 580 euros.
By the way, it's also very difficult to get a "E" pump right now.
I just saw that you installed a pump from an automatic transmission in a manual transmission car.
That doesn't fit at all. There are 3 different pumps available for this engine (AKE).
We should chat on the phone sometime.
Jörg
Translated on 01-11-2026, 23:41.
Post29-06-2011, 20:59    Subject: AKE Power Loss: Causes and Solutions Quote
@ @udi:
a) Aren't you doing a bit too much self-promotion there?
b)
I don't actually need the exact error codes either, since they differ from testing device to testing device
, really?
Translated on 01-11-2026, 23:42.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss AUY 85 kW: Causes & Solutions Diesel Engine Technology
No new posts G3 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Power loss and ABS Diesel Engine Technology
No new posts Performance Loss Above 130 km/h (AJM) Diesel Engine Technology
