Passat NW worn out
chli1976
Karma: +185 / -0   Thank you, like it!
Post04-11-2011, 18:44    Subject: Passat NW worn out Quote
I have a Passat AVF with 250,000 km that's making a rattling noise and a dull "thumping" sound.
The dull "clattering" sound is clearly coming from the worn camshafts, as the valves are no longer opening completely.
When I accelerate, I hear a brighter noise, and I'm not 100% sure if it's coming from the valves that aren't opening, or if there's also a defect in the crankshaft mechanism.
The owner said the noise appeared suddenly, but it's good that it's a woman, although some people might notice if it gradually gets louder.
The owner doesn't want to invest as much money anymore, and the camshaft with the hydraulic lifters is also quite expensive.
Would you also replace the bearing shells of the NW (presumably referring to a specific engine or component)?
In MWB 13, only the 2-cylinder engine was noticeable.
What do you think about that?
Here's another video.
[url][/url]http://www.youtube.com/watch?v=eiLY3wKRmgU{MARKER}
 Ein gute Passat TDI Nockenwelle
 File size:  2 MB
 Viewed:  867 times
 Eine der Passat TDI Nockenwellen mit verschlissenen Nocken
 File size:  2.05 MB
 Viewed:  1088 times
VCDS
mullemaus
Post04-11-2011, 19:50    Subject: Passat NW worn out Quote
Are you sure the squeaking noise only comes from the worn-out bearings? I would rather suspect the hydraulic components, as they are likely a major cause of the 'wear-related' noise. With that, and the wrong oil – it's all just a mess.
You can replace the NW bearing shells, as they usually wear out after 150,000 km. icon_wink.gif
Post04-11-2011, 20:59    Subject: Passat NW worn out Quote
Most likely a valve mechanism, but unfortunately I can't really make out much from the pictures. Is there another version of the video available for uploading in the thread (for some reason, it wasn't made available that way)?
chli1976
Post04-11-2011, 21:47    Subject: Passat NW worn out Quote
mullemaus wrote:
Are you sure that the squeaking only comes from the worn-out wheel bearings? I would rather look at the hydraulic components, as I think they are largely responsible for the "wear-related" noise. With that, and the wrong oil – it's all just a mess.
You can replace the bearing shells of the NW engine; they usually wear out after 150,000 km anyway. icon_wink.gif
"Hydros" are naturally included.
VCDS
chli1976
Post07-11-2011, 13:22    Subject: Passat NW worn out Quote
"The TPI report indicates quality deviations in the valve lifters and the camshaft."
VCDS
chli1976
Post11-11-2011, 22:04    Subject: Passat NW worn out Quote
Today I installed new valve cover gaskets, tappet adjusters, and bearing shells, and now it's running smoothly again.
VCDS
Post11-11-2011, 22:11    Subject: Passat NW worn out Quote
No new posts Worn clutch disc pressure plate bearing, Golf/Bora 85KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Worn Clutch? Get Clutch Replacement Now! Diesel Engine Technology
No new posts Worn synchronizer rings? Diesel Engine Technology
No new posts Uneven brake wear Transmission, Chassis, Body & Interior
No new posts When are fuel injectors worn out? Diesel Engine Technology
