Audi A4 B5 AFN Voltage Problem
Didi_n
Registered VCDS User
Post15-11-2011, 16:24    Subject: Audi A4 B5 AFN Voltage Problem Quote
Hello everyone,
I have a problem with my A B5 Avant 110PS TDI AFN. Maybe someone here has a tip for me, even though it's not a specific diagnostic problem right now.
The vehicle no longer starts, there are no warning lights illuminated on the dashboard, and nothing electrical seems to be working. However, the battery is not completely discharged, and neither does attaching a jump starter box make any difference. Also, even systems that don't rely on the ignition switch, etc., such as the hazard warning light system, do not function.
Does anyone have a possible solution?
Didi
DieselBär30x
Avatar-DieselBär30x
Post15-11-2011, 16:48    Subject: Audi A4 B5 AFN Voltage Problem Quote
Hi Didi!
Solution Approach: Use a measuring device to measure voltages!
Start with the battery and, if necessary, locate and fix any interruptions (especially the ground wire!).
Best regards from Munich!
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post15-11-2011, 17:09    Subject: Audi A4 B5 AFN Voltage Problem Quote
Interior locking, ignition switch, or (+) terminal of the power distribution box should be tightened.
To remove the cover under the steering wheel.
reflexsilber met.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6: Troubleshooting Electrical Issues Transmission, Chassis, Body & Interior
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts Audi 80 B4 On-Board Diagnostics (OBD)
