Audi 80 B3 Diagnosis: Troubleshooting Guide
Karma: +1343 / -0   Thank you, like it!
Post27-11-2011, 20:58    Subject: Audi 80 B3 Diagnosis: Troubleshooting Guide Quote
I want to use VCDS to read the control module (MSG) on an Audi 80 B3 (year of manufacture 1989, 2.0 liter gasoline engine, engine code 3A).
The 2x2 adapter connectors, black/white, that are located on the central electrical system, as found in my Audi 80 B4, are not present. Instead, there are two similar black/brown connectors located in the footwell on the driver's side. I can only assume that these are diagnostic connectors.
What I found was the link:
http://www.20v-sauger-tuning.de/blinkcode.htm
Is this method already the ultimate solution?
Translated on 23-09-2026, 22:09.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post27-11-2011, 21:09    Subject: Audi 80 B3 Diagnosis: Troubleshooting Guide Quote
Yep, that's all there is. What problems does he have, or better yet, let's list the problems he *doesn't* have. Nobody wants to spend the money to make it run properly.
reflexsilber met.
Translated on 23-09-2026, 22:11.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts Audi A6 Diagnosis: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Diagnosis in the Audi V8 On-Board Diagnostics (OBD)
No new posts Golf IV/Audi A4 Diagnostic Interface On-Board Diagnostics (OBD)
No new posts Audi V8 D11: Diagnosis Not Possible On-Board Diagnostics (OBD)
