Help! I need assistance.
Erik
Post21-05-2003, 22:32    Subject: Help! I need assistance. Quote
Okay, so I was at the workshop, and my mass airflow sensor (MAF sensor) was showing very high values. They replaced it, but it didn't fix the problem.
It took me too long to fix everything, so I ended up taking it home. The problem was a faulty pressure sensor in the intake manifold.
but it was deleted, a test drive was done, and it never reappeared.
What should I do?
I want to clean my turbocharger. How do I do it, and do I need to adjust anything afterward?
My car also produces soot from around the year 2000.
I experience a slight shaking or vibration between 1700 and 2000 RPM, but only when the engine is under full load.
I want to start doing something about it tomorrow, please help me quickly.
I'm going crazy.
best regards, erik
or what else could be the reason?
I have a chip implanted.
Translated on 09-10-2026, 8:48.
Golfmann
Post21-05-2003, 23:35    Subject: Help! I need assistance. Quote
was hast du für ein Auto und was für einen Motor? Loutput?
What kind of chip is this? Is it in the control unit or a separate box? Perhaps it's for disabling something?
Ralf
Translated on 09-10-2026, 8:50.
Erik
Post22-05-2003, 15:05    Subject: Help! I need assistance. Quote
I have an AFN engine.
and a Wetterau chip.
135,000 km
Andy
Post22-05-2003, 17:27    Subject: Help! Urgent assistance needed. Quote
Hi Erik,
so, so, I was at the workshop, and my mass airflow sensor (MAF) was showing very high values, so it was replaced, but it didn't fix anything.
What should I do?
Too high values? Are you sure about that? And вообще?!? icon_question.gif icon_question.gif
I want to clean my turbo. How do I do it, and do I need to adjust anything afterward ?
Clean? With water and soap, or something? What's the point? Where would the dirt be? The only reason I can think of would be a stuck VTG. You can find a lot of information about that through a search. icon_eek.gif
My car also produces soot starting from 2000.
I'm going crazy.
best regards, erik
I have a chip inside.
Just try describing your problem in more detail. No one can do anything with these fragments.
Furthermore, in a post dated April 23, 2003, you mention that you have a Quick-Chip installed. At that time, your troubled AFN was already experiencing misfires (according to the post). Changing the chip tuner certainly won't solve these kinds of problems. icon_evil.gif
If you want to understand the whole thing (as you mentioned in a previous post), then remove the §%$%§/ chip and start troubleshooting with VAG-COM, data logging, and a keen eye on the track. icon_exclaim.gif
Best, Andy.
Translated on 09-10-2026, 8:52.
No new posts SEO: "Best SEO Tools: Improve Your Rankings Now" Diesel Engine Technology
No new posts help with solenoid valve On-Board Diagnostics (OBD)
No new posts VAG-COM Diagnostics: Help with Data Analysis Diesel Engine Technology
This topic is locked, you cannot edit or reply. VAG-COM: Change Injection Start - Help Diesel Engine Technology
