VTG Function: Your Questions Answered
Achim
Post05-04-2003, 13:10    Subject: VTG Function: Your Questions Answered Quote
What should an optimally configured boost pressure curve look like?
According to my LDA (likely referring to a diagnostic tool or reading), the boost pressure increases sharply when the accelerator pedal is pressed quickly.
It is then increased to 1.4 to 1.5 bar and subsequently reduced to approximately 1 bar.
It then adjusts to approximately 1.2 bar. The car has been tuned with a chip.
Now, my question:
Is that normal, or is it also possible to achieve this by adjusting...?
Reaching the threaded rod on the VTG container, following the...
The pressure immediately reaches the target value of 1.2 bar.
without losing its vibrancy.
Translated on 08-09-2026, 14:33.
Post05-04-2003, 16:26    Subject: VTG Function: Your Questions Answered Quote
Hi Achim,
If everything goes well, you can achieve the desired effect by adjusting the VTG.
It's also possible that the VTG (Variable Transmission Gear) is sticking, which would make the overshoots "rougher."
Translated on 08-09-2026, 14:34.
Achim
Post05-04-2003, 22:46    Subject: VTG Function: Your Questions Answered Quote
Hi Ulf,
I'm not sure if I understood your answer correctly.
I was thinking about extending the threaded rod to...
Keep the overswing smaller, so that, after the overswing...
Do not adjust it again towards lower boost pressure.
I must. However, I fear that this might cause weakness at the start.
brings.
Translated on 08-09-2026, 14:35.
Post06-04-2003, 8:48    Subject: VTG Function: Your Questions Answered Quote
Achim wrote:
Hi ulf,
I was thinking about extending the threaded rod...
That's exactly what I meant.
Translated on 08-09-2026, 14:36.
No new posts Data Collection for Standard Turbocharger Control. Diesel Engine Technology
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
No new posts MWB 11: Questions and Answers On-Board Diagnostics (OBD)
No new posts Question about the AGR system in the ACV/T4 (Sorry) Diesel Engine Technology
