konjoy Guest
23-06-2004, 13:48 Subject: V6 TDI Injectors for AHU Engine |
I'm sorry if this topic has already been discussed. Unfortunately, I couldn't find an answer to my question. Do the injectors from an Audi A6 2.5 TDI V6 150PS fit into an Audi A4 with an AHU engine? Does anyone know what the injector opening size is, and what effect that would have?
Translated on 20-10-2026, 1:03.
23-06-2004, 13:54 Subject: V6 TDI Injectors for AHU Engine |
The Duesem V6 engines are definitely longer.
Also, all 6 are the same length, unlike in a 4-cylinder engine where the one with the NHG is longer.
You will definitely have problems with the cables.
Unfortunately, I don't know if the nozzles will fit or if the claws (retention devices) will fit.
Translated on 20-10-2026, 1:04.
Profile PM Garage |
konjoy Guest
23-06-2004, 14:01 Subject: V6 TDI Injectors for AHU Engine |
Okay, so it seems the issue is resolved. We'll install the injectors from the AFN then.
Translated on 20-10-2026, 1:05.
donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
23-06-2004, 16:11 Subject: V6 TDI Injectors for AHU Engine |
@konjoy:
The injectors from the V6 engine definitely won't fit, because the V6 has a displacement of 416 cm^3 per cylinder, while the R4 engines have a displacement of 475 cm^3.
As a result, the entire piston geometry is different, and the nozzle openings are also smaller.
Alex.
Touran 1.9 TDI, EZ 09/2004
