Exhaust Performance: Low RPM Issues?
Go to page: 1, 2, 3  Next
servusssss
Karma: +12 / -0   Thank you, like it!
Post07-01-2008, 20:36    Subject: Exhaust Performance: Low RPM Issues? Quote
"On my Audi A4 Avant quattro 2.0 TDI 170 hp, manufactured in Germany in February 2007 and equipped with a DPF, I'm experiencing occasional power loss at lower engine speeds."
Sometimes, when starting uphill, the engine stalls.
However, this lack of performance is not always present.
Since I had already been to the dealership, and they told me it was due to the engine not being fully broken in, I've now driven another 20,000 km, but the problem is still the same.
Daher war ich wider in der Werkstatt, jetzt vermuten die Freundlichen einen def. LLM.
However, was this diagnosis made without any measurements being taken?
Since I have VCDS, I've done some tests myself.
First, I checked the clutch/brake pedal assembly and the accelerator pedal, as well as the temperature sensors and pressure sensors. All of these sensors are working correctly or are practically identical to each other.
I noticed a difference between the target and actual boost pressure in the lower RPM range.
Due to my limited knowledge and experience in evaluating measurement data, I would appreciate any opinions and assessments of the logs.
Link to the logs:
[url] https://community.dieselschrauber.org/en/viewtopic.php?t=17730 [/url]
Christian
P.S.: Why is the driver's desired torque specified in Nm?
Translated on 18-08-2026, 23:46.
vagtuning
Post13-01-2008, 1:32    Subject: Exhaust Performance: Low RPM Issues? Quote
The data used has now been updated for the third time.
I would try updating the software first.
Currently, the software version (SW) is 9888 for the German market (BRD).
Translated on 18-08-2026, 23:48.
servusssss
Post13-01-2008, 19:05    Subject: Exhaust Performance: Low RPM Issues? Quote
Thank you for your reply, vagtuning!
The update should be something that the friendly staff can install.
Unfortunately, I wonder if they know that there is new software available. The car has been to the workshop several times due to a lack of power. icon_eek.gif
Are there any issues with the software update process, or are there other reasons why the service department is hesitant to perform the update?
I couldn't find anything in the search results, so is it possible to upload software (SW) using VAG-Com as well?
I will ask the friendly team about a new software and see what they think.
I will post any updates as they become available.
Best regards, Christian.
Translated on 18-08-2026, 23:50.
Malte1408
Post13-01-2008, 19:50    Subject: Exhaust Performance: Low RPM Issues? Quote
He's building a very bad foundation for the project.
It's just a suspicion, but could you please log the data from MWB 3 while it's idling?
And log a basic setting in the MWB 3.
Both are about 45 seconds long.
Translated on 18-08-2026, 23:51.
servusssss
Post14-01-2008, 20:48    Subject: Exhaust Performance: Low RPM Issues? Quote
Hello Malte1408,
I've logged it.
You can find it at the following link:
/viewtopic.php?p=124658#124658
The idle log lasts for about a minute.
When logging the basic settings, I followed what VAG-COM indicated.
When I accelerated, the engine vibrated a lot. Which I think is normal.
For information:
Today, I received a message from the customer service team stating that I am supposed to receive a new mass airflow sensor (MAF).
The low-mileage mechanic (LMM) is almost a standard diagnosis at dealerships, or is that a plausible explanation for the poor acceleration?
The car is going to the dealership next week; let's see what else they do regarding software updates, etc.
Translated on 18-08-2026, 23:53.
Malte1408
Post14-01-2008, 22:32    Subject: Exhaust Performance: Low RPM Issues? Quote
Hello, greetings!
My suspicion was not confirmed. I thought the EGR valve might be stuck, but it doesn't seem to be the case.
I'm not sure what else to say about it. It seems like it's too new for me to understand.
But could someone perhaps explain why it's necessary to apply full power to initiate the basic calibration process in the MWB 3 system?
Translated on 18-08-2026, 23:55.
servusssss
Post15-01-2008, 8:03    Subject: Exhaust Performance: Low RPM Issues? Quote
Hello.
Thank you anyway for your effort!
As soon as I have something new, I'll post it.
Hansemann82
2007 Audi A4
Post15-01-2008, 18:15    Subject: Exhaust Performance: Low RPM Issues? Quote
Hello.
It might be a good idea to have the clutch checked as well!
The pressure plate installed from the factory corrodes very quickly. Before the friction material wears away after just a few kilometers, the clutch slips significantly, which, given the engine's poor low-end torque, can sometimes cause it to stall.
I had the same problem; there's now a revised print plate and a "technical bulletin" or similar document from Audi.
The problem has been fixed with the new version.
Greetings.
John.
A4 Limo BRD
Translated on 18-08-2026, 23:56.
servusssss
Post15-01-2008, 20:51    Subject: Exhaust Performance: Low RPM Issues? Quote
Hello.
The clutch was also a topic of discussion.
The car has had a problem with starting since I've owned it.
I live at an altitude of 1100 meters and drive up and down the mountain every day.
This makes the starting problem very frustrating, especially when there is snow and you really need power to get going. In response to my initial complaints, I was told that I am missing the biting point icon_mad.gif, which I don't believe.
I drove the same route for years in my Beetle and rarely stalled the engine.
I'm going to ask the support team again if there isn't a modified print plate available. I'm curious to see what their response will be.
Thank you for the information, Hansemann82.
Translated on 18-08-2026, 23:58.
Hansemann82
2007 Audi A4
Post16-01-2008, 8:08    Subject: Exhaust Performance: Low RPM Issues? Quote
The TPL (Technical Product Lifecycle) document with the printing plate applies to all A4 models built within a specific timeframe and equipped with a manual transmission, featuring the 2.0 TDI engine; this includes both 103 kW and 125 kW versions, as well as all drive types and body styles.
Unfortunately, they need to be able to understand the problem before they are allowed to switch.
Good luck and get well soon to the driver.
Cheers!
John.
A4 Limo BRD
Translated on 19-08-2026, 0:00.
Post16-01-2008, 14:45    Subject: Exhaust Performance: Low RPM Issues? Quote
Does this issue of "disks corroding" also apply to BMR drives?
Due to the possibility of aftermarket parts being installed, it could also be entirely different components.
Only my BMR feels very rough when cold, which perfectly matches the description above.
Translated on 19-08-2026, 0:01.
Hansemann82
2007 Audi A4
Post16-01-2008, 16:04    Subject: Exhaust Performance: Low RPM Issues? Quote
dieselmartin wrote:
Does this "disk corrosion" also apply to BMR?
Only my BMR feels very rough when cold, which exactly matches the description above.
Unfortunately, I cannot provide you with that information.
"Rupfen" typically occurs in cold and humid weather conditions.
If Audi offers a recall (TPL - "Technische Produktionsänderung"), then perhaps Volkswagen will too, if they have the same problem.
Just ask your local Volkswagen dealer; they should know about that.
John.
A4 Limo BRD
Translated on 19-08-2026, 0:03.
Post16-01-2008, 16:29    Subject: Exhaust Performance: Low RPM Issues? Quote
I highly doubt that.
Finally, I had to tell them that there was new software for the BMR, (which will happen again soon icon_wink.gif), and that I wanted to have it.
Translated on 19-08-2026, 0:04.
servusssss
Post16-01-2008, 19:15    Subject: Exhaust Performance: Low RPM Issues? Quote
Hello dieselmartin,
Have you ever checked the boost pressure of your engine between 1000 and 2500 RPM?
In this area, it seems like my device is not generating enough boost pressure.
With K-Power, I'm getting 280 N of force at 1750 RPM instead of 350 N.
I'll upload the diagram to the logs.
Translated on 19-08-2026, 0:05.
Hansemann82
2007 Audi A4
Post17-01-2008, 10:41    Subject: Exhaust Performance: Low RPM Issues? Quote
@dieselmartinViewing profile: dieselmartin: They should check the system using the vehicle identification number (VIN)! Be persistent or visit another authorized dealer! You can do it icon_lol.gif.
@servusssssViewing profile: servusssss: The lack of performance in the BRD (likely referring to a specific vehicle or engine) is a major topic right now. I think there was an update released that should help, but vag-tuning already mentioned that it's likely due to outdated software. It seems to be caused by carbon buildup on the fuel injectors.
I recently added Liqui Moly's diesel fuel additive to my tank as a test, even though I hadn't had any previous issues with my car, and I think it responds slightly better now; it definitely runs more smoothly with it. It might be useful for you too.
When the engine runs as it should, it's absolutely fantastic!
Greetings.
John.
A4 Limo BRD
Translated on 19-08-2026, 0:07.
pschaefer
Post17-01-2008, 14:25    Subject: Exhaust Performance: Low RPM Issues? Quote
How? Is the 1184 already obsolete again?
Peter.
Translated on 19-08-2026, 0:09.
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL: No Power at Low RPM Diesel Engine Technology
No new posts Engine Performance Issues: Low RPM Problems Diesel Engine Technology
No new posts V6 TDI, Leistungsverlust im unteren Drehzahlbereich Diesel Engine Technology
No new posts FORD 1.8 TD - Power loss in the low-speed range Diesel Engine Technology
