Steering Column Warranty: What You Need to Know
Uwe
Post27-03-2003, 14:39    Subject: Steering Column Warranty: What You Need to Know Quote
Hi!
Bei unserem A4 Bj. 4/2000 und 60.000 Km entstehen beim Lenken Schleifgeräusche mir unbekannter Ursache aus dem Bereich des Lenkrades. Es hört sich an, als würde irgendwas an der Lenkradnabe scheuern. Die Werkstatt meint, die Lenksäule müsse getauscht werden. Kulanz: Absolutely nothing!
What options do I have? Shouldn't this be covered under a good will policy? What about self-repair? Does anyone else experience this problem?
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 15-08-2026, 1:49.
Rudi
Post27-03-2003, 14:59    Subject: Steering Column Warranty: What You Need to Know Quote
Hello Uwe,
'Mine does that occasionally too. The cause has always been dirt on the contact ring of the horn. To fix it, you can try threading a piece of sturdy fabric through the opening, guiding it to clean the contact surface, and then pulling it out lengthwise along the contact ring to clean it.'
Be careful when threading to ensure that the grinding contact does not get bent.
Best regards, Rudi.
Translated on 15-08-2026, 1:50.
Uwe
Post27-03-2003, 15:28    Subject: Steering Column Warranty: What You Need to Know Quote
Okay, thanks, I'll try it right away. Just one more question: How does a goodwill arrangement look for my specific case?
Uwe
Uwe
Post30-03-2003, 12:44    Subject: Steering Column Warranty: What You Need to Know Quote
I checked today, and it's definitely not the contact point. The noise is coming from the joint area on the splash guard. There's a bearing there through which the steering column passes. It's not entirely clear, but I think the bearing itself is fixed, and the steering column is rotating inside the bearing. There's also some slight wear next to it. I also feel that the steering is becoming slightly stiffer.
It looks like getting to that part involves quite a bit of work. I would have preferred to have it done at the workshop if there was any warranty coverage.
Workshop statement: NONE!
Does anyone know more details about the terms and conditions regarding goodwill or concessions?
Uwe
Translated on 15-08-2026, 1:51.
Uwe
Post05-04-2003, 19:28    Subject: Steering Column Warranty: What You Need to Know Quote
Uwe wrote:
Does anyone know more details about the goodwill conditions?
Does anyone really know anything about this???
Fahrzeug A4 Bj. 4/2000, 60.000 Km, Lenksäule defekt. Gibts dazu ne Schadennummer? Goodwill?
Uwe
Translated on 15-08-2026, 1:53.
Post06-04-2003, 8:26    Subject: Steering Column Warranty: What You Need to Know Quote
Hi Uwe,
Since the goodwill conditions at VAG have changed, decisions are made on a case-by-case basis. However, since this is a defect that is not typical for the mileage of the vehicle, the chances of receiving goodwill coverage may be quite good.
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg documentation, clacking sounds coming from the st... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error light, indication of defective lamps General Tips
No new posts Battery Warranty: What You Need to Know Diesel Engine Technology
No new posts Drive shaft replacement: Is it covered? Diesel Engine Technology
No new posts Grace for Turbo? Diesel Engine Technology
No new posts Kulanz Costs: What You Need to Know Diesel Engine Technology
