Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm (Solution)
vrsechs
Registered VCDS User
Post02-04-2012, 21:05    Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Quote
Hello everyone in the forum community,
Unfortunately, I couldn't find the error in the search function as I usually do, so I'm writing to you about it.
"The problem car is a 2006 Sharan BRT with 265,000 km. I had the DPF (Diesel Particulate Filter) cleaned about 15,000 km ago."
The engine runs smoothly when it's cold, and the idle is normal, as is typical for a PD engine.
The problem only occurs when the engine is warm, approximately from 60 degrees Celsius.
Then the following happens: You'll experience significant jolting or shaking when accelerating or driving at a constant speed, starting around 3rd gear. The engine runs from approximately 1100 RPM to around 2600 RPM, and then it pulls strongly all the way to the end (I didn't dare to go to its maximum speed).
The idle speed control shows good values when the engine is cold, within a range of plus or minus 1. However, the situation is different when the engine is warm. When the engine misfires, the idle becomes very rough, and the idle speed control goes to its maximum setting (level 3). Cylinder partially filled to maximum pressure +2.99mg/H.
LOG-01-001-xxx-xxx-sharan.CSV
 File name:  LOG-01-001-xxx-xxx-sharan.CSV
 File size:  5.88 KB
 Downloaded:  944 times
LOG-01-011-003-067-sharan.CSV
 File name:  LOG-01-011-003-067-sharan.CSV
 File size:  5.14 KB
 Downloaded:  722 times
LOG-01-013-xxx-xxx.CSV
 File name:  LOG-01-013-xxx-xxx.CSV
 File size:  36.03 KB
 Downloaded:  691 times
LOG-01-013-007-067-sharan-warm.CSV
 warmer motor
warmer motor
 File name:  LOG-01-013-007-067-sharan-warm.CSV
 File size:  11.56 KB
 Downloaded:  777 times
LOG-01-013-004-005sharan-kalt.CSV
 kalter motor
kalter motor
 File name:  LOG-01-013-004-005sharan-kalt.CSV
 File size:  20.87 KB
 Downloaded:  770 times
Karma: +807 / -0   Thank you, like it!
Post02-04-2012, 21:22    Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Quote
I removed the bottom part of the post because it wasn't relevant, and I didn't feel like correcting all the errors. Please put in a little more effort.
A typical cause for this type of "error" would be assembly errors in the PD unit. Please replace the gasket, preferably with a new one, and reassemble with cleaned and inspected sealing surfaces, ensuring proper alignment and adjustment.
BM
Avatar-BM
Post03-04-2012, 0:05    Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Quote
In addition, I would like to expand and swap a second PD (presumably referring to a "power distribution" or similar component). If the error persists, at least we can see whether it's moving along with the system or not.
3B5 AJM
vrsechs
Post03-04-2012, 16:16    Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Quote
Hey, so, I probably shouldn't become an author icon_redface.gif. But it's good that you're taking care of things and keeping them organized.
Okay, so I'm going to have the PDEs (presumably referring to something specific in this context) expanded and cleaned, and also have a cross-exchange performed.
Can we continue running the PDEs like this, or should we switch them back after this? Greetings.
BM
Avatar-BM
Post03-04-2012, 17:21    Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Quote
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation. Don't forget to adjust the basic settings of the PDs.
3B5 AJM
vrsechs
Post16-04-2012, 10:18    Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Quote
I've now had all the PDE components ultrasonically cleaned, replaced the seals, and performed the initial adjustment (which was easier than I thought). And everything is working properly again, just like it did on the first day. BIG THANK YOU.
Post16-04-2012, 11:33    Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Quote
Ratings - Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm
No new posts Document: PD Motor Stalling When Accelerating, Tandem Pump Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia I 1999 - Front wipers only work when it's dry General Tips
No new posts 1.9 TDI BLS engine stalls at traffic lights when the engi... Diesel Engine Technology
No new posts TDI No Power When Warm: Log File Analysis On-Board Diagnostics (OBD)
No new posts Diesel Engine Misfire: Why It Happens & Fixes On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Tiguan 2.0 TDI: Intermittent Starting Issues (Warm Engine) Diesel Engine Technology
