alevuz Schrauber
Joined: 11/27/2011 Posts: 113 Karma: +32 / -0 Location: Tirol
16-12-2012, 10:46 Subject: PDE Wiring Harness Issues: Troubleshooting & Repair |
Hello and good morning.
Are there any known instances of these faulty wiring harnesses occurring only in specific engines (e.g., MKB - BKD), or does this issue also extend to other engines, such as mine (MKB: AYH)?
Thank you very much.
Sure, here's the translation:
"SG, Alevuz" Golf V 2.0 TDI - 4motion (BKD) im Ruhezustand mit >500Tkm
Touareg V10 TDI (AYH)
Translated on 14-08-2026, 15:01.
16-12-2012, 11:06 Subject: PDE Wiring Harness Issues: Troubleshooting & Repair |
It's likely that very few people here have worked on V10 TDI engines.
But I don't see why the same thing shouldn't happen there. It's unlikely to be any better just because it says "V10" on it... MfG. Michael
Translated on 14-08-2026, 15:02.
Profile PM Garage |
alevuz Schrauber
16-12-2012, 11:31 Subject: PDE Wiring Harness Issues: Troubleshooting & Repair |
Hello...
Yes, you are right, but let's rephrase the question like this:
V10 = yes, and there are already enough cars with two R5 engines and vans equipped with the R5 TDI engine driving around.
Are there any experiences with the R5 models? They seem to be the same components, just used twice.
Sure thing! Please provide the German text you would like me to translate into English. I will only provide the translation without any explanations.
Aevuz. Golf V 2.0 TDI - 4motion (BKD) im Ruhezustand mit >500Tkm
Translated on 14-08-2026, 15:03.
pa-mm6 Blaumann
18-12-2012, 20:57 Subject: PDE Wiring Harness Issues: Troubleshooting & Repair |
Hi, I'm also having the same problem with the wiring harness on my BRD. This is already the fourth one installed. It seems to fail almost every year when it gets cold. I constantly check the part number in the system to see if anything changes, but it doesn't look like it will. Apparently, the wiring harnesses don't handle "extreme" cold very well...
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email. Audi SQ5 8R Cvub
Translated on 14-08-2026, 15:04.
Profile PM Email |
