dokky Blaumann
Joined: 11/14/2003 Posts: 67 Karma: +7 / -0 Location: im Grünen 2013 Volkswagen Golf Free account, no CAN development support
13-04-2012, 16:52 Subject: No Speed Limit - Fiat Bravo 1.9 MJet 16V |
Hi there,
After a winter mostly spent driving short distances, I took the car back onto the highway and noticed that it no longer reaches speeds above 195 km/h according to the speedometer. Before, it would consistently reach around 220 km/h.
I visited the mechanic and had the error codes read from the car's computer (OBD). All values were within the normal range, so no conclusions could be drawn.
Do you have any ideas? Could it be the turbocharger or the EGR valve, which is known to cause problems in the 1.9 diesel Fiat and can also affect the boost pressure sensor?
Translated on 20-07-2026, 21:31.
Profile PM Garage |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
13-04-2012, 23:41 Subject: No Speed Limit - Fiat Bravo 1.9 MJet 16V |
Could it be the LMM (lambda sensor), or is the VTG (vanos valve) clogged due to frequent short trips?
Greetings. Kaum macht man es richtig, funktioniert es!
Translated on 20-07-2026, 21:32.
Profile PM Garage |
dokky Blaumann
17-04-2012, 9:06 Subject: No Speed Limit - Fiat Bravo 1.9 MJet 16V |
Hi there,
"VTG is common. You can clearly see how the linkage moves when starting."
Does it make sense to verschandeln the boost pressure sensor sometimes?
Translated on 20-07-2026, 21:33.
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
19-04-2012, 20:54 Subject: No Speed Limit - Fiat Bravo 1.9 MJet 16V |
If the Fiat isn't going into limp mode (otherwise it wouldn't be able to reach 195 km/h).
It's most likely due to the aging mass airflow sensor (MAF). If maintenance is neglected, it could also be a completely clogged air filter. A slightly clogged catalytic converter or aftermarket diesel particulate filter (DPF) can also cause this – try driving for a longer distance to "burn it off."
If it were an EGR valve, it would produce a lot of black smoke and have low power.
You can easily verschandeln the LD sensor; it won't hurt anything.
If the measured LD pressure values are incorrect, the MSTG system will enter emergency mode, and an error message will be logged. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 20-07-2026, 21:34.
Profile PM Email Garage |
dokky Blaumann
14-05-2012, 14:07 Subject: No Speed Limit - Fiat Bravo 1.9 MJet 16V |
A clogged particulate filter is not the issue. I have already regenerated the DPF, and now I will reluctantly bite the bullet and invest in a new mass airflow sensor (MAF).
Translated on 20-07-2026, 21:36.
Profile PM Garage |
dokky Blaumann
14-06-2012, 12:16 Subject: No Speed Limit - Fiat Bravo 1.9 MJet 16V |
Hi there,
A small crack in a vacuum hose was the culprit.
Profile PM Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7812 Karma: +1090 / -0 Location: BAR
14-06-2012, 13:17 Subject: No Speed Limit - Fiat Bravo 1.9 MJet 16V |
Thank you for the solution! Where was it located, and how was it found? Automobile Zeitzeugen: |SUZUKI Swift Sport (2008)| |Smart 450 (2002)| |Honda CB 125 F (2018)|
Translated on 20-07-2026, 21:37.
