Audi A4 8E: Parts, Repair & Info
KANE326
Post22-05-2012, 9:22    Subject: Audi A4 8E: Parts, Repair & Info Quote
Hello everyone,
I have a question... Specifically, on this S4 B6, there are no K and L lines at the diagnostic connector. Instead, we have bl/sw on pin 1, brown on pins 4 & 5, and CAN on pins 6 & 14. I don't know what the rest of the pins are right now. But I always thought that all B6 models had these K and L lines!
"Additionally, I'm unable to access the diagnostic system with one of my testers. It's not detecting any control units. However, using a ScanGauge2, I can query real-time data via the CAN bus and clear error codes from the engine control unit."
I don't understand! Why doesn't it work with the ScanGauge and the Audi diagnostic tools? (I've obviously tried several).
Could it be because the complete Vehicle Identification Number (VIN) isn't yet entered in the car's system? (That could also explain why the airbag light is on after 10 minutes.)
HELP!
Translated on 31-07-2026, 16:56.
Post22-05-2012, 10:38    Subject: Audi A4 8E: Parts, Repair & Info Quote
"Why is the VIN missing? That would definitely make me worry..."
Translated on 31-07-2026, 16:57.
KANE326
Post22-05-2012, 13:01    Subject: Audi A4 8E: Parts, Repair & Info Quote
I know why that is icon_rolleyes.gif.
Okay, so the tester is checking the combination instrument (which acts as a gateway) via the diagnostic CAN bus and isn't detecting a valid VIN.
"Does Scangauge matter?"
Sure, here's the translation:
"Is that correct?"
Translated on 31-07-2026, 16:58.
Post23-05-2012, 14:42    Subject: Audi A4 8E: Parts, Repair & Info Quote
http://wiki.ross-tech.com/wiki/index.php/01794
Permanent problem solution: Replace the combination instrument.
Translated on 31-07-2026, 16:59.
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts LOG Audi 2.5 AKE Upload
No new posts Audi AFB STG: Repair & Replacement Diesel Engine Technology
