Passat 3C Cold Start Diagnosis LED Lights
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
anywhere
Post28-04-2012, 21:04    Subject: Passat 3C Cold Start Diagnosis LED Lights Quote
Hi everyone,
I was just trying to drive my Passat 3C, manufactured in 09, and then I heard the comment "Nice disco!"...
I have ALL cold diagnoses activated, while a comparable Passat only has brake lights, turn signals, side markers, and parking lights activated.
If I disable the central "active cold diagnosis" (= it's no longer a diagnosis), then it stops flashing.
"But I haven't been able to see this behavior in any other car - is my control unit simply incorrectly coded?" Does a cold diagnosis even help with LEDs?
Marco
Passat 3C Cold Start Diagnosis LED Lights - VID_20120428_194639.3gp
 Kaltdiagnose Leuchten am Passat 3C mit LEDs
 File size:  6.55 MB
 Viewed:  3934 times
Karma: +784 / -0   Thank you, like it!
Post28-04-2012, 21:15    Subject: Passat 3C Cold Start Diagnosis LED Lights Quote
I assume that no errors are currently being detected in the lights.
Does a cold diagnosis with LEDs actually achieve anything?
If, for example, you disconnect the taillight connector and then a warning message appears in the dashboard: Yes icon_wink.gif
Best regards, Rainer
Post07-05-2012, 11:50    Subject: Passat 3C Cold Start Diagnosis LED Lights Quote
... but the disco is clearly visible from inside (brake light) and from outside (rear/stand light).
What is your BNSTG?
anywhere
Post07-05-2012, 13:14    Subject: Passat 3C Cold Start Diagnosis LED Lights Quote
[code]Address 09: Busbar Label file: RKS\3C0-937-049-30-H.lbl
Part Number: SW; 3C8 937 049 F HW; 3C8 937 049 F
Component: Main Bus Switchgear H54 2602
Revision: 00H54000 Serial Number: 00000009456503
Encoding: E70A0E4701041A05470A80000F000000E40FFF475C000100000000000000
Operating number: WSC 56176 133 81653
VCID: 3462BFC957204E9
Subsystem 1 - Part Number: 3C1 955 419 A Label file: RKS\1KX-955-119.CLB
Part Number: Wiper 241108 004 0206
Encoding: 00046997
Operating Number: WSC 56176
Subsystem 2 - Part Number: 1K0 955 559 AH Label file: RKS\1K0-955-559-AG.CLB
Component: RLS 190309 054 0402
Encoding: 00208936
No errors found.
Post07-05-2012, 13:47    Subject: Passat 3C Cold Start Diagnosis LED Lights Quote
Cool, that CC unit with a heatable windshield.
Let's see what my 3C8-E has to say about the disco.
Georg-TDI
Post12-05-2012, 20:42    Subject: Passat 3C Cold Start Diagnosis LED Lights Quote
Here is the encoding (from the tool):
Part Number SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Junction Box H54 2602
Revision: 00H54000 Seriennummer: 00000009220313
Encoding: E1888F0700041A00470A00000F00000000095D435C000120000000000000
Operating Number: WSC 05124 000 00000
VCID: 334BD746522E491
Subsystem 1 - Part Number: 3C1 955 419 B Label File: RKS\1KX-955-119.CLB
Part Number: Wiper 260410 006 0208
Encoding: 00046997
Component: RLS 190109 054 0402
Encoding: 00208936
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts Werkstattaktion Ladeluftschlauch, Passat B5, 74/96 KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B: Kat vom 110 PS TDI an den 115 PS PD TDI? Diesel Engine Technology
No new posts MFL Passat 3BG Electrical Systems, Vehicle Electronics, Multimedia
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat AJM Durchzugsprobleme Diesel Engine Technology
