Hi Kuddl!
Okay, there was still some oil in the engine, but the oil pressure was definitely gone.
The question primarily focused on the mechanical condition of the air intake manifold (specifically, the side where air is drawn in).
Based on your description, I assume that significant fragments and abrasive particles entered the intake air path and consequently reached the AJM (?).
Regarding the "3-Pot Run":
Quote: |
| Every skilled mechanic can recognize it by the sound and the feel. |
Okay, then I am neither talented nor do I have feelings.
Exactly what I was looking for, I've been searching for ages, LLRR values are OK, but the ZMS was defective.
Unfortunately, I'm not familiar with Gutmann testers and therefore cannot assist you with their operation or interpretation of results.
In summary, it involves the simultaneous recording of values for idle speed control, power delivery engine (PDE) states, and variations in PDE switching times.
With VCDS, the mandatory measurement blocks would be numbers 13, 18, and 23.
Support for users without a valid VCDS or Bavarian (whatever-BMW-thingy) license is no longer provided, especially when an analysis in that direction is required. (Sorry.)
Therefore, if I observe subtle LLRR patterns, I would tend to look for explanations in a different direction â with or without talent/intuition
Otherwise, check for debris in the low-pressure (LL) circuit. Then REPLACE the LL cooler!!!! *important* And use an endoscope to inspect the valves, piston rings (PDEs), pistons, etc., inside the engine for any consequential damage.
Best regards from Munich!
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
