vwSchrauber Profi-Schrauber
17-12-2012, 13:39 Subject: Low-cost bypass filter |
Here are a few thoughts from last weekend:
As a low-cost alternative to a bypass filter or fine filter (less than 5-7 μm), a fuel filter without a drain plug (made of plastic) can be used.
For example, these could be models WK723, WK731, etc., or, if you need a larger size, WK962/4.
The filter is mounted on a universal filter head with M14x1.5 connections.
It's important not to eliminate the throttle, as this would result in too much oil pressure being lost through the bypass. In this case, an "OUT" screw from a Bosch VE pump with a 0.55mm bore would be suitable. Since it has a 12x1.5 thread, an adapter from 14x1.5 to 12x1.5 is required here.
The entire system is connected, for example, using hollow screws and ring terminals, with low-pressure hydraulic hose (20-30 bar), ideally as thin as possible (6mm). selber schrauben - statt Werkstattpfusch
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
Autoservice likes this. |
17-12-2012, 21:08 Subject: Low-cost bypass filter |
Hm, what's the point of all this  ? No more oil changes? NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
17-12-2012, 22:18 Subject: Low-cost bypass filter |
The ways of the Lord are mysterious. Hopefully, nothing bad happened to him.  LG, Onkel BM
19-12-2012, 20:17 Subject: Low-cost bypass filter |
There are engines that only have an oil filter screen, which results in relatively short oil change intervals and, consequently, higher wear. Here, it is often cheaper and easier to use a  bypass filter . selber schrauben - statt Werkstattpfusch
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2560 Karma: +595 / -0 Location: bei Zwickau
19-12-2012, 21:49 Subject: Low-cost bypass filter |
Hi!
Where are we right now?
Lawnmowers, pre-war tractors, plate compactors? Grüße, Steffen!
vwSchrauber likes this. |
19-12-2012, 22:09 Subject: Low-cost bypass filter |
For example, the VW Beetle and the original Fiat 500 only have a very basic oil filter. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
20-12-2012, 9:24 Subject: Low-cost bypass filter |
Quote: | | Lawnmowers, pre-war tractors, plate compactors? |
Generators, for example... where an oil change is often quite tedious, especially in soundproofed versions  . selber schrauben - statt Werkstattpfusch
