A4 Side Pocket Bag
Leon
Post13-04-2003, 17:15    Subject: A4 Side Pocket Bag Quote
Hello everyone!
'The airbag warning light has recently started illuminating on my A4 (year 1997). The control unit shows an intermittent error message: 'Driver's seat side airbag - resistance too high'.'
Will the airbag fail immediately, or is it just a problem with the connectors? What's the best way to check this? What resistance value should I simulate for the control unit as a replacement? Or is this error known to occur with this type of system?
Thank you in advance.
Translated on 11-09-2026, 5:07.
Andy
Post13-04-2003, 20:18    Subject: A4 Side Pocket Bag Quote
If I remember correctly, this error is a known issue. In my opinion, it was due to a faulty connector. As far as I know, the solution was to replace the connector with a soldered connection.
But the search function will probably be able to help you more precisely.
Best, Andy.
Translated on 11-09-2026, 5:08.
Leon
Post14-04-2003, 16:53    Subject: A4 Side Pocket Bag Quote
Thank you, I've already found something. icon_biggrin.gif I will look into it after Easter and will let you know if it worked out.
Thank you very much again.
Translated on 11-09-2026, 5:09.
