A4 8E Oil Pan Removal: Guide & Instructions
TDIMaster
Post15-08-2012, 17:20    Subject: A4 8E Oil Pan Removal: Guide & Instructions Quote
Hello forum!
Has anyone ever gone through the trouble of removing the oil pan on an A4 B6/B7?
I'm now facing the task of replacing the drive mechanism of the balance shaft module (as mentioned in a previous post of mine).
It's often said: "Lift the engine up, lower the front axle carrier icon_rolleyes.gif".
Has anyone ever done this before? Is it feasible to do this on-site?
Please help me!!!
Best, Sascha.
Translated on 03-09-2026, 14:55.
Back to top Profile PM Email
Post16-08-2012, 12:07    Subject: A4 8E Oil Pan Removal: Guide & Instructions Quote
Is that feasible at the mine?
I think so. However, you should jack up the vehicle sufficiently to create enough space underneath, on both the left and right sides, for the removal and installation.
Translated on 03-09-2026, 14:56.
vwSchrauber
Post24-08-2012, 12:41    Subject: A4 8E Oil Pan Removal: Guide & Instructions Quote
It works the same way as it does on the Passat 3B/3BG.
Loosen the screws on the front axle carrier, then lower it.
Loosen the gearbox mounting, which will create pivot points in the two side engine mounts. To prevent damage to the mounts, the nuts on these can also be loosened.
Then, using a workshop crane (or possibly another method), lift the engine from the front.
Translated on 03-09-2026, 14:57.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ölwanne ausbauen Diesel Engine Technology
No new posts Oil Sump Spray Tube: Causes & Solutions Diesel Engine Technology
No new posts Oil Pan Gasket 1Z Diesel Engine Technology
No new posts 2.5 TDI: Parts found in the oil pan Diesel Engine Technology
