Clean DPF: Full Diesel Particulate Filter?
elyias1
Post02-01-2013, 1:29    Subject: verschandeln DPF: Full Diesel Particulate Filter? Quote
beim Vertraut machen mit diesem Forum bin ich auch die DPF Thread`s gestoßen. Die Ermittlung der Aschemenge in unserem Passat beträgt 65g. Der Ruß wird jetzt wohl oft verbrannt. Beim Loggen gestern lag der Wert bei 3 bis 4% und wurde heute schon wieder verbrannt. FaCycling distance: 100 km.
I still have some questions about how to obtain the spare parts.
In our P car, the engine was replaced in 2010. Where can I find the current engine code on the engine block? On all the places I've checked so far, it still says "BMP." The turbocharger and exhaust system are still from 2005.
After cleaning the DPF (Diesel Particulate Filter), the differential pressure sensor should also be replaced.
Is the current spare part number 076906051A?
Is the login code for customization displayed by VCDS?
After cleaning and adjusting the ash content, is only the new ash value entered?
Thank you for your help.
LOG-01-011-067-068.CSV
 Logdatei von den Filterumgebungswerten
 File name:  LOG-01-011-067-068.CSV
 File size:  16.36 KB
 Downloaded:  1312 times
Log-NVP-EJ505-WVWZZZ3CZ6P023613-222290km.txt
 Aktueller Autoscan.
Aktueller Autoscan.
 File name:  Log-NVP-EJ505-WVWZZZ3CZ6P023613-222290km.txt
 File size:  11.39 KB
 Downloaded:  1076 times
Passat 3C 2.0 TDI BMP 6 Gang Schalter
Fabia 2.0
Pontiac Transsport 2.3 Schalter
"Am Ende wird alles gut. Wenn es nicht gut ist, dann ist es nicht das Ende..." Oskar Wilde
Translated on 13-08-2026, 14:01.
Post02-01-2013, 11:36    Subject: verschandeln DPF: Full Diesel Particulate Filter? Quote
After cleaning the DPF, the differential pressure sensor should also be replaced.
Since the differential pressure sensor is not actually related to the removal of the diesel particulate filter, a preliminary replacement is quite pointless. After all, it can always be replaced with very little effort if it is defective. icon_idea.gif
At the very least, it should have lasted a long time based on the mileage shown in the car's scan data. icon_wink.gif
See also:
/viewtopic.php?t=26437&highlight=dpf
/viewtopic.php?t=23802&highlight=differential pressure sensor failure
That would be more interesting.
1 error found:
000564 - Charge pressure control.
P0234 - 000 - Limit exceeded - Intermittent.
Environmental conditions:
Error status: 00110000
Error priority: 1.
Error frequency: 1.
Mileage: 221766 km
Time: 0.
Date: 2012.12.22
Time: 10:54:34
Driven without a DPF?
Translated on 13-08-2026, 14:05.
elyias1
Post02-01-2013, 16:32    Subject: verschandeln DPF: Full Diesel Particulate Filter? Quote
Hello Rainer,
No, never; I actually want to start working on the DPF now. I only came across this issue because of your website. The P system hasn't shown any error messages yet. And even though the part was last checked in November at the icon_smile.gif, there was no indication from there either.
Wo sind am Motorblock die Kennbuchstaben zu finden? Die anderen Stellen helfen mir nicht weiter. See also above.
Jens
Fabia 2.0
Translated on 13-08-2026, 14:08.
Post02-01-2013, 16:34    Subject: verschandeln DPF: Full Diesel Particulate Filter? Quote
Your engine code is BMP, which can also be found on the sticker in your service booklet.
Translated on 13-08-2026, 14:09.
elyias1
Post02-01-2013, 19:42    Subject: verschandeln DPF: Full Diesel Particulate Filter? Quote
Hello Rainer,
"However, the engine was replaced in 2010 because the drive gear of the oil pump was worn out. The workshop said that the new engine has a different oil pump design... meaning it doesn't have balance shafts?!"
Is that still the BMP engine?
Jens
Fabia 2.0
Translated on 13-08-2026, 14:10.
Post02-01-2013, 19:56    Subject: verschandeln DPF: Full Diesel Particulate Filter? Quote
The balance shaft modules have been modified multiple times, even though the engine code remained the same.
elyias1
Post02-01-2013, 20:52    Subject: verschandeln DPF: Full Diesel Particulate Filter? Quote
Hello Rainer,
Thank you for the answers; I learned a lot again.
Jens
Fabia 2.0
Translated on 13-08-2026, 14:11.
elyias1
Post09-01-2013, 23:28    Subject: verschandeln DPF: Full Diesel Particulate Filter? Quote
The DPF is now empty and back under the car. The removal and installation took 2 days, mainly because we had to keep getting different tools. icon_smile.gif
I followed your instructions.
"Expansion of the DPF (Diesel Particulate Filter) for the Passat 3C with BMP engine." icon_smile.gif Great.
Here are the notes I have:
Without removing the AGR valve, nothing can be done. I disconnected the "exhaust gas outlet" from above using a 10mm open-end wrench with an adapter for a 40mm Torx bit.
If the AGR valve has been removed, the top surface of the DPF is directly underneath it.
and thus the first temperature sensor (SW17), the oxygen sensor (SW22), and the first connection for the piping of the differential pressure sensor (SW17).
Up top, everything was done with adjustable wrenches, but down below, a proper open-end wrench (slightly bent) had to be used on the differential pressure sensor connection, and the whole thing was heated up with a torch. The open-end wrench can only be fitted after the PDF has been partially unscrewed.
I detached the driveshaft from the transmission using a multi-tooth wrench (M10), which made it much easier.
To flush it, I sealed the end of the tube with a spray nozzle cap and the lower pressure connection with the original pipe and tape. Then, I attached a 3/4" hose and clamp to the temperature port and started the water flow.
Then, for the first time, I modified data in the engine control unit.
In channel 12 of the adaptation settings, the ash value was set to 4g.
Now I am observing when the regeneration process will be initiated again.
Jens
 AGR und der Knarrenmaulschlüssel für die Abgaszuleitung
 File size:  471.08 KB
 Viewed:  5335 times
 Ansaugrohr Passat 3C BMP
 File size:  530.67 KB
 Viewed:  9975 times
Fabia 2.0
Translated on 13-08-2026, 14:13.
Baba
Registered VCDS User
Post11-01-2013, 14:15    Subject: verschandeln DPF: Full Diesel Particulate Filter? Quote
Hello elyias1,
You could have saved yourself the trouble of expanding the AGR system for "next time." Simply rotate the clamp on the turbocharger so that you can access it from below with a 40mm Torx wrench. It's likely that the clamp on your Passat was twisted in an unfavorable position. However, you still need two extensions from below, but icon_confused.gif is then not a problem.
On the right side, during the second assembly/disassembly, I had propped up the passive component to keep the drive shaft out of the way.
"For my car, the flushing obviously didn't work. About six months later, I got a DPF from a salvaged vehicle with only 40,000 km on it at a good price – it's now installed, and I can relax for a while."
The main difference from the "old" one is that this one smells less and rarely regenerates. The state of charge increases very slowly (1.8% after 180 km). With the old one, after approximately the same distance, the state of charge was already between 10-20%.
I've also learned that even an old, heavily clogged Diesel Particulate Filter (DPF) can still be sold for around €150 to a scrap metal dealer. Apparently, the precious metals (platinum?) contained in the catalytic converter are even more valuable.
Roland.
Translated on 13-08-2026, 14:18.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts DPF & Environmental Zones: Quick FAQ Technical Articles
No new posts P2458 - Diesel Particulate Filter, Regeneration Duration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 4F 3.0 TDI - Exhaust, Diesel Particulate Filter... Diesel Engine Technology
No new posts Diesel particulate filter DPF, Audi A3 CAYC Diesel Engine Technology
No new posts Werte Dieselpartikelfilter interpretieren Diesel Engine Technology
No new posts CFWA - Diesel Particulate Filter Malfunction Diesel Engine Technology
