Error codes 19804/P3348 (Solution)
Karma: +807 / -0   Thank you, like it!
Post03-09-2012, 16:53    Subject: Error codes 19804/P3348 Quote
Error code 19804: Control unit for exhaust turbocharger 1 (J724) malfunction.
Error P3348 - 005 - electrical - intermittent.
Possible causes:
- Circuit breaker tripped/faulty.
- Wiring or connector to the actuator is faulty.
- Actuator J724 is defective.
The J724 is tested via a selective actuator test within the engine control unit.
Attention: For 3.0l TDI engines (ASB/BKS/BMK/BNG) with errors in the throttle module, before taking any further actions, first resolve the errors in the throttle module, as the error J724 may be a secondary error.
Translated on 14-07-2026, 20:21.
Ratings - Error codes 19804/P3348
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their causes for MKB AJM, ATJ, AVF, AWX Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 Error Codes: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts ASV Error Codes: Troubleshooting & Solutions Diesel Engine Technology
No new posts VAG-COM error codes On-Board Diagnostics (OBD)
No new posts Error Codes: Troubleshooting & Solutions On-Board Diagnostics (OBD)
