windl Guest
29-04-2003, 13:53 Subject: Golf 4 Headlights: Replacement & Upgrade |
Does anyone know if the headlight mounting brackets are compatible between the Golf IV headlights?
'Can you replace them, meaning if any are broken, can you replace them with ones from a headlight that has good mounts? Just the mounts!'
Translated on 25-09-2026, 1:13.
kenny Guest
29-04-2003, 14:52 Subject: Golf 4 Headlights: Replacement & Upgrade |
There's a repair kit available, I'm not sure if it's directly from VW or from somewhere else. I also had the suspension break once.
Translated on 25-09-2026, 1:14.
windl Guest
29-04-2003, 14:54 Subject: Golf 4 Headlights: Replacement & Upgrade |
Can the brackets be swapped, meaning can you move them from one headlight to the other? Or what does the repair kit look like? Does it include new brackets, or is it just an adhesive solution?
DaBibo Blaumann
29-04-2003, 16:14 Subject: SEO-Optimized Title Translation:
"Best German Translation Services | Fast & Accurate" |
Part number 1J0 998 225, screw-on type, if I recall correctly.
Translated on 25-09-2026, 1:15.
