T3 Killerscrew: 1Z Thread Repair
Go to page: 1, 2, 3  Next
New Topic 🔒 Locked 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
Post26-07-2011, 22:13    Subject: T3 Killerscrew: 1Z Thread Repair Quote
In southern Croatia, I noticed that the vibrations felt different somehow, and at the same time, when reversing or stopped at a red light with a tailwind, I could smell that the exhaust fumes had a certain "late" odor, and this happened occasionally.
Da ich im Urlaub auf Lappi und somit auf VCDS verzichte konnte ich nur manuell prĂŒfen, nachdem wir nen schönen Platz am Strand hatten untersuchte ich den Motor nach AuffĂ€lligkeiten wie ZR-Spannung,ZR selber usw.. entdeckte spĂ€ter leicht Eierende KW Riemenscheibe die voher nie dagewesen war , also 19 er RingschlĂŒssel ran oha, ist fast locker diese SCH... Schrdawn...
"Borrow me a large wrench to tighten the KW screw. We continued our vacation by repeatedly tightening the screw each time, and we drove a total of 2400 km since discovering the loose KW screw. At home, I removed the exhaust, took out the timing chain cover, and removed the screw and the ZR sprocket. It looks like this is just the beginning."
[img]/download.php?id=6026[/img]
Okay, let's start planning then...
[img]/download.php?id=6027[/img]
That's what you'll look like after planning.
[img]/download.php?id=6028[/img]
After that, in my opinion, the reduction gear had too much lateral play, about 1 mm.
So, there are some weld points on it (Unfortunately, only one weld point is visible in the picture).
[img]/download.php?id=6029[/img]
After filing it to the correct size, the ZR component should fit without any play.
and the threads on the KW screws have been deburred.
[img]/download.php?id=6030[/img]
Tightened and then a thick weld applied.
[img]/download.php?id=6031[/img]
Now I hope that this damn screw can't be easily opened by itself anymore!
Of course, the timing chain tensioner (Siri), crankshaft pulley (NW), and intermediate shaft were replaced, as well as all the other timing components.
I'm curious to see how long this whole thing will last! Tomorrow, Wednesday, I'm driving this old clunker to the Czech Republic, near the Slovakian border, a round trip of almost 2000 km. Let's see how it holds up.
Translated on 30-07-2026, 16:17.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post26-07-2011, 22:44    Subject: T3 Killerscrew: 1Z Thread Repair Quote
I think the solution is really great; you can only hope that the shaft seal hasn't been damaged by the heat icon_wink.gif.
I might have just added a small punctuation mark to make it easier to solve later.
Greetings.
Translated on 30-07-2026, 16:20.
Post26-07-2011, 22:49    Subject: T3 Killerscrew: 1Z Thread Repair Quote
Don't worry, it was cooled with compressed air icon_wink.gif.
If the sprocket needs to be removed, I'll just use a flexible tool icon_idea.gif.
Translated on 30-07-2026, 16:21.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post26-07-2011, 22:55    Subject: T3 Killerscrew: 1Z Thread Repair Quote
reflexsilber met.
LZ
Post27-07-2011, 11:19    Subject: T3 Killerscrew: 1Z Thread Repair Quote
The only meaningful solution for this flawed design. But next time, use CO2 or refrigerant spray to cool it down!
Translated on 30-07-2026, 16:22.
klahaui
Avatar-klahaui
Post27-07-2011, 15:37    Subject: T3 Killerscrew: 1Z Thread Repair Quote
Electrically welded?
Karma: +1344 / -0   Thank you, like it!
Post27-07-2011, 17:50    Subject: T3 Killerscrew: 1Z Thread Repair Quote
Are you able to fit the vibration damper on correctly and centered?
Otherwise, it should last for a while. Let's see when the cracks start to appear. The weld points on the crankshaft certainly won't extend its lifespan.
klahaui
Avatar-klahaui
Post27-07-2011, 20:50    Subject: T3 Killerscrew: 1Z Thread Repair Quote
Are you referring to the imbalance caused by the welding process?
Translated on 30-07-2026, 16:23.
RedR32
Avatar-RedR32
Post27-07-2011, 21:16    Subject: T3 Killerscrew: 1Z Thread Repair Quote
I would have definitely left out the crankshaft pulley and instead welded the timing belt sprocket directly to the crankshaft. icon_lol.gif icon_lol.gif icon_lol.gif
reflexsilber met.
Post28-07-2011, 12:50    Subject: T3 Killerscrew: 1Z Thread Repair Quote
I'm afraid the spot weld doesn't have a positive impact on durability.
Based on my subjective assessment, the screw is unlikely to come loose completely. The initial problem is more likely to be a stretching of the screw. This leads to play and consequently a reduction in its holding force.
Once this holding force is reduced, the screw may also loosen further, but it will likely have little impact on the underlying problem.
It's also worth noting that in the event of a repair, a harder screw is used, which is less likely to stretch.
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 30-07-2026, 16:24.
RedR32
Avatar-RedR32
Post28-07-2011, 12:57    Subject: T3 Killerscrew: 1Z Thread Repair Translating...
[Translating...]
reflexsilber met.
Team100
dieselschrauber and TDI-GTI-4-Motion likes this.
Post29-07-2011, 23:32    Subject: T3 Killerscrew: 1Z Thread Repair Quote
The issue with the crankshaft bolt has been on my mind for a while, although thankfully I haven't had the displeasure of dealing with it directly yet – despite having two of these engines.
- I believe that the welding process is very unfavorable because the heating will cause a portion of the tensile force generated by expansion to be lost, as well as local structural effects on the screw head and subsequently the shank.
- The main question is how the damage actually occurs. It's always talked about as being caused by a decrease in the clamping force of the screw – I don't quite understand that. It would mean that every structure using expansion screws needs to be questioned, and classified as unsafe if it loses its clamping force over time.
- "Self-loosening" would be another possible cause of loosening – in this type of connection, it is quite conceivable due to the acceleration processes of a combustion engine crankshaft (which is why alternators have a freewheel). However, I consider this scenario unlikely due to the large contact area of the screw head and the need for rotation relative to the timing pulley wheel. This could be easily checked by marking the screw head with break-sensitive paint; even slight rotations would be clearly visible during regular inspections.
- A more likely scenario is the tearing or shearing of the pressure surface between the timing pulley and the crankshaft, which also has to transmit dynamic load components.
I believe this area is simply at the limit of its design capacity. Due to various factors, micro-movements can occur in the contact surface, leading to material wear and deformation. This creates a cascading effect because as the distance between the support points decreases – the points where the bolt stretches – the clamping pressure also decreases due to the weakening tension force of the bolt.
I'll explain the difference between the old and new screw versions simply by saying that the new screw can generate a higher clamping pressure due to its material properties, as the elastic range of deformation allows it without causing permanent distortion. This means that the new screw offers more safety against failure of the friction surface because of the increased clamping pressure.
- I see the following potential hazards: The contact surface is formed by the crankshaft and the pulley. Therefore, the material properties of the gear wheel are crucial for the durability of the connection. Now, these wheels come from various suppliers, so there may be differences in material hardness, and the surface roughness of the force-transmitting face could also vary.
- Unfortunately, various belt drives and also the vibration damper are attached. These components themselves, as well as the aggregates they drive, are responsible for the forces acting on the critical connection. In addition to dynamic components, there is also a static tensile force due to the leverage effect of the belts.
- Regarding the vibration damper: I am familiar with two designs so far: One has a belt contact surface mounted on rubber elements. I consider this design to be advantageous because the transmission of belt force through the rubber results in a more uniform torque distribution to the auxiliary drives.
The second variant (which apparently is only available now from febi) has a continuous aluminum body extending to the belt contact surface, and the rubber element and weight are located within the cavity of the pulley. This design likely transmits the rotational dynamics of the crankshaft directly to the timing belt.
It remains to be seen whether these design features ultimately contribute to a catastrophic failure. Perhaps users who have experienced such failures could report on the type of vibration dampers they had installed.
My car with 640,000 km has the tread pattern glued on, while the one with 350,000 km has the solid version.
- I see a significant influence from the temperature: The bolt is directly "heated" by the crankshaft, while the timing belt pulley is massively cooled thanks to the attached "heat sink" = vibration damper, especially in winter when it's really cold.
"Certainly, the screw will expand due to the heat, while the gear is more likely to shrink when it's extremely cold outside. The clamping force of the screw will decrease – and the foundation for a major disaster is laid. I can imagine that driving at full speed in temperatures of minus 20 degrees Celsius could have quite an effect here."
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day.
What possible solutions are there for this problem?
I consider it almost impossible for the screw to tighten itself; welding won't help in that situation.
I also found the method of using pins with hollow tips, which are drilled into the pressing surface, to be counterproductive: they reduce the valuable friction area, but on the other hand, they cannot transmit a high-frequency dynamic moment because they are too elastic. Ultimately, the pins or their holes will also wear down.
So, there isn't much left to say about that:
- Surface conditioning: One could work towards achieving the optimal surface of the press fit area. A surface that is too smooth is undesirable, and one that is too rough is also problematic, as the surface will deform. Grease should definitely be avoided, and Loctite will likely not provide any benefit. Leaking grease from the crankshaft can be prevented by degreasing the pressing surface immediately before assembly.
- Manufacturer and material properties of the timing pulley:
It would also be interesting to know which brands of timing belt pulleys were used in cases involving "killer screw" effects. Perhaps only certain manufacturers are prone to causing these problems?
- The issue of which vibration damper design is better (monoblock or split).
- The temperature issue: Expansion of the bolt and contraction of the timing pulley. Here, I would try to cool the crankshaft bolt. This would be easy to do by drilling two small holes on either side through the timing pulley: one should hit the bolt channel at the front, and one at the back. After tightening the crankshaft bolt, a commercially available thermal paste is pressed through the front hole until it comes out at the back; the holes should then be closed with pins.
Now, the screw would definitely be at the temperature of the timing pulley, and based on the title, there can no longer be any loss of tensile strength.
However: Fortunately, I haven't had to try this method yet, and there is no guarantee that it will help or that any side effects might occur. But if I were in that situation: I would try it - at least more so than welding or stiffening. icon_wink.gif
Here are a few more complex ideas for discussion:
- Fabrication of a longer expansion bolt and corresponding spacers to provide more allowance for thermal expansion.
- Creating a separate sleeve with a pressing face: Advantage: the material can be specifically chosen. Disadvantage: manufacturing is difficult. The gear would need to be reamed and shrunk accordingly.
Please consider all of this as ideas and thoughts on the topic. They don't necessarily have to be correct, and I welcome any opinions you may have.
Audi 80 TDI 1Z, B4, Bj 93, Limo, 670000 km ... das Wunderauto
Audi 80 TDI 1Z, B4, Bj 95, Avant, 390000 km ... das Backupauto
Translated on 30-07-2026, 16:33.
JSPatrick
Registered VCDS User
Post30-07-2011, 22:20    Subject: T3 Killerscrew: 1Z Thread Repair Quote
I've solved something similar before, but I noticed something while welding.
that the two materials don't readily bond together.
I noticed while welding (TIG) that the materials weren't fusing together properly!
I really hope this lasts!
Translated on 30-07-2026, 16:43.
Post31-07-2011, 23:53    Subject: T3 Killerscrew: 1Z Thread Repair Quote
Okay, after driving 1968 kilometers round trip from the deep interior of Czechia near Slovakia, the only thing I fixed was the right windshield wiper; I just tightened the wiper arm screw in Prague. The drive was trouble-free. Every time I refueled or stopped the engine, I carefully checked the crankshaft bolt, and nothing seems to be moving there; the pulley is running smoothly. I'm curious to see how long this all lasts! The Siri [likely referring to a specific part or system] is absolutely tight, just like the entire engine icon_smile.gif.
However, during the journey there, I occasionally experienced very short, hard jolts; I suspect the needle valve injector is failing. This issue disappeared after refueling in the Czech Republic, although the Eastern European diesel produced a lot of foam and it took a long time to fill the tank completely icon_eek.gif. Perhaps it disappeared more specifically after turning off the ignition after refueling and then restarting the engine icon_question.gif. So far, this hard jolting has not occurred again.
I should probably try the NHG test sometime.
Error memory is empty icon_eek.gif.
Team100:
I believe the crankshaft pulley (KW) problem is more likely to occur at idle and very low RPM due to the large vibrations. This can be clearly seen (or heard) when the belt tensioner is faulty, as you can hear it vibrating at low speeds. However, this vibration disappears as the engine speed increases.
My TDI has spent many hours running in "limp mode" while being used as a generator to power onboard batteries and large consumers via an inverter. I prefer using 0.4-0.6 liters of diesel rather than lugging around an old, heavy, smelly generator that consumes more than 1 liter per hour and is neither quieter nor more environmentally friendly than the TDI. After all, what's the point of having a powerful 120A generator on board in the TDI? icon_idea.gif
(I understand that the TDI's starter motor doesn't deliver its full 120 amps in low light conditions, more like 60 amps. I only need a maximum of 45 amps in low light.)
JSPatrick:
With MAG welding, I was able to weld without problems; I experimented with the old KW screw and gear until I found the correct settings. icon_idea.gif
I tightened the ratchet wrench on the clamp and tried to loosen it, but it was held incredibly tight.
I wouldn't use TIG welding because the KW-Siri generates too much heat, which could cause melting.
Translated on 30-07-2026, 16:46.
Post01-08-2011, 19:47    Subject: T3 Killerscrew: 1Z Thread Repair Quote
"Yes, with compressed air, it's easy to grind down the weld seams that are protruding too much. The V-belt pulley still fits perfectly without any play."
Translated on 30-07-2026, 16:50.
jarobaldu
Karma: +40 / -0   Thank you, like it!
Post02-08-2011, 13:15    Subject: T3 Killerscrew: 1Z Thread Repair Quote
Hi there,
Does this problem only occur with the 1Z model, or are the AFNs also affected?
The welding method made me chuckle quite a bit, but I also believe it won't achieve anything: the loss of preload has already been mentioned here.
A.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 30-07-2026, 16:51.
