Leaky AVF AGR Valve: Causes & Fixes
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
Faxe
Post11-11-2012, 14:48    Subject: Leaky AVF AGR Valve: Causes & Fixes Quote
'On my Passat with the AVF engine and 290,000 km on the odometer, I'm experiencing an issue where oil is increasingly leaking out of two holes located to the right and left of the pressure sensor on the AGR valve, and this oil then drips down onto the exhaust manifold.'
My question is: Is there a repair kit available for the AGR valve, or do I have to replace it completely?
This part number is printed as: 038 131 501 AA.
Has anyone here ever used a complete set purchased from eBay? Are there any other recommended options, or is it best to go with the expensive one from a dealer?
[Book link]
Faxes.
Translated on 30-07-2026, 0:29.
Post11-11-2012, 15:28    Subject: Leaky AVF AGR Valve: Causes & Fixes Quote
I would go with Pierburg. The stuff you find on online marketplaces is often a gamble.
Regardless, they're all feeling a little bit of pressure.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 30-07-2026, 0:30.
Faxe
Post11-11-2012, 19:04    Subject: Leaky AVF AGR Valve: Causes & Fixes Quote
Here's a photo; does this still count as 'sweating'?
I wiped the oil off the drill bit; there's so much of it.
that it's leaking from the exhaust manifold.
Is Wahler also a possible manufacturer as an alternative to Pierburg?
Faxes.
 AGR AVF
das Öl kommt aus der Bohrung raus
 File size:  1.05 MB
 Viewed:  3318 times
Translated on 30-07-2026, 0:31.
Post11-11-2012, 19:14    Subject: Leaky AVF AGR Valve: Causes & Fixes Quote
My AGR looks like this after 100,000 km. Nothing has changed or worsened during that time. About 1-2 times per year, the pressure washer is used anyway icon_wink.gif.
Unfortunately, I cannot provide any information about Zu Wahler as an agricultural cooperative (AGR).
Translated on 30-07-2026, 0:32.
mullemaus
Post11-11-2012, 19:34    Subject: Leaky AVF AGR Valve: Causes & Fixes Quote
Faxes.
That is too much for the MOT test icon_sad.gif.
You can use Wahler instead of Pierburg. Wahler is just as good in terms of quality icon_wink.gif.
Translated on 30-07-2026, 0:33.
Post11-11-2012, 22:40    Subject: Leaky AVF AGR Valve: Causes & Fixes Quote
As long as it doesn't leak excessively, doesn't oil the engine block, and isn't filled with oil in the engine protection pan, the vehicle inspector won't say anything, unless they are a highly trained inspector who will find something to complain about even in a brand new car.
It's anyway well hidden by the fairing icon_mrgreen.gif.
It looks the same on my Spanish car.
The engine will be washed every year, usually in the middle to end of May. icon_wink.gif
Translated on 30-07-2026, 0:35.
mullemaus
Post11-11-2012, 22:45    Subject: Leaky AVF AGR Valve: Causes & Fixes Quote
There is so much of it that it's leaking onto the exhaust manifold.
Translated on 30-07-2026, 0:36.
Post11-11-2012, 22:56    Subject: Leaky AVF AGR Valve: Causes & Fixes Quote
Oops, I really missed something there icon_eek.gif.
Post12-11-2012, 13:37    Subject: Leaky AVF AGR Valve: Causes & Fixes Quote
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Dam... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B2 CV Joint Leak: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Defective candle Diesel Engine Technology
No new posts ABS/ESP Leak: Find the Source! Diesel Engine Technology
No new posts ESP Leak / Seals: Causes & Solutions Diesel Engine Technology
No new posts Leaky Oil Filter: Causes & Solutions Diesel Engine Technology
