Oil stain under the car - transmission fluid or brake fluid? (Solution)
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
oldewurtel
Post22-10-2012, 21:09    Subject: Oil stain under the car - transmission fluid or brake fluid? Quote
Hello fellow enthusiasts,
My usually reliable vehicle (see below) is currently experiencing a minor 'incontinence' issue.
I discovered a small, yellowish, oily stain in the garage.
First, I thought it might be brake fluid (rubbing it between my fingers, it lacks that oily feel), but after inspecting the underside, I didn't find any traces on the underbody panel icon_confused.gif.
It was only on the lift that I saw a yellowish drip hanging from the transmission bell housing, directly above the middle mounting bolt of the front underbody panel (at the ventilation opening) icon_twisted.gif! There were no visible signs on the outside, so it definitely originates from inside the transmission housing.
Now, the question (before I bring out the big guns):
1.) Could it be brake fluid leaking from the clutch slave cylinder (I'm not familiar with the internal design of the clutch actuation system on the transmission)?
2.) Defective oil seal --> but is it transmission oil? I have never heard of damaged shaft seals in these gearboxes (DHF) before.
I look forward to your replies.
Best regards, Oldi.
Post22-10-2012, 21:14    Subject: Oil stain under the car - transmission fluid or brake fluid? Quote
If the liquid dissolves in water, it's likely brake fluid; otherwise, it's most likely transmission oil.
oldewurtel
Post22-10-2012, 21:39    Subject: Oil stain under the car - transmission fluid or brake fluid? Quote
Hello Autoservice,
Thank you for the tip icon_exclaim.gif.
I will examine the new stain immediately (now I've cleaned everything up nicely).
However, I had the feeling that the liquid washed off very easily with water from my fingers, so I'm hoping it's brake fluid...
Does the receiver cylinder leak more often?
Best regards, Oldi.
oldewurtel
Post25-10-2012, 21:38    Subject: Oil stain under the car - transmission fluid or brake fluid? Quote
It was (fortunately) actually brake fluid that was leaking from the transmission bell housing icon_rolleyes.gif!
With the mention of the water solubility of brake fluid (yet another thank you to 'autoservice' for the incredibly quick tip), it quickly became clear what was lurking on the garage floor... icon_wink.gif
After I saw the exploded diagram of the gearbox with the clutch slave cylinder installed, it was clear that the leak must be coming from that hydraulic component.
BTW: It's hard to believe, but the clutch feels noticeably smoother, even though the cylinders are identical (both are VW-AUDI parts, 8D0 721 257, manufactured by Sachs).
Best regards, Oldi.
You are not permitted to view these file(s), please log in or register for extended rights or status updates.
Post25-10-2012, 22:51    Subject: Oil stain under the car - transmission fluid or brake fluid? Quote
Luckily, it was only the cylinder, and thank you for the feedback icon_wink.gif.
Ratings - Oil stain under the car - transmission fluid or brake fluid?
No new posts Automotive Technology: Topics & Resources Technical Articles
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Used Car: Age vs. Mileage - Which Matters Most? Diesel Engine Technology
No new posts VW Recall: Buy Auto Bild or Read Online Diesel Engine Technology
No new posts Golf V - Automatic Lock and Automatic Unlock On-Board Diagnostics (OBD)
No new posts Water Damage ASZ: Causes & Prevention Diesel Engine Technology
