Hello fellow enthusiasts,
My A4 has been experiencing a problem with an oil-soaked turbocharger boost hose, and the leakage of this lubricant is becoming increasingly noticeable in the engine compartment
Upon closer inspection, nothing was initially detected, but after removing the hose (from the ATL towards the transverse pipe) and applying slight bending stress, a crack was identified at the transition to the quick-release coupling
And that's where my little problem begins.
When I upgraded the new VNT17/GT1749A on my AFN a few years ago, I was able to find a used charge air hose from a Passat (3B0 145 828 G) for only €10. I removed the quick-release connector on the cross pipe side, and everything worked
There are three options for a new hose:
1. 3B0 145 828 G: The quick-release fastener must be removed.
2. 8E0 145 834 M: Does not have a quick-connect fitting on the transverse pipe side. Does it fit in terms of length and diameter?
3. GT-Adapter aus dem Admin-Shop + alter Schlauch: Leider nicht (mehr) gelistet. Price?
When I called today about the part number 8E0 145 834 M, my jaw nearly dropped: 157€ for this little piece of hose!!!
The 3B0 145 828 G will likely be in the same price range...
Technically, I prefer either the adapter or the very expensive '8E hose'. The advantage is that you can use standard VAG parts.
Does the adapter solution have any drawbacks in terms of fluid dynamics?
I look forward to your replies.
Oldi.
