Thomas_Alt Blaumann
Joined: 12/30/2008 Posts: 27 Karma: +2 / -0 Location: Rattiszell
18-08-2011, 8:51 Subject: Parking Assist T5 |
Hello everyone,
I have a T5 from 2010 (7HC) where the parking brake no longer works. I have the following errors stored in the memory:
Thursday, August 18, 2011, 08:47:12:01988
VCDS Version: RKS 10.6.4
Address 10: Parking Assist 2 Label file: RKS\7E0-919-475.clb
Part number: 7E0 919 475 A HW: 7E0 919 475 A
Part and/or Version: PARKHILFE 8K H10 0008
Encoding: 110001
Operating Number: WSC 02756 790 50316
ASAM Dataset: EV_VW75XParkAssis8K A01003 (VN75)
VCID: 3064C842DAB3
1 Error found:
13632256 - Function restriction due to missing message
U1111 00 [009] - -
Environmental Conditions:
Error Status: 00000001
Error Priority: 6
Frequency of Errors: 1
Lost Count: 52
Mileage: 15284 km
Date: 2019.14.14
Time: 08:37:04
Unfortunately, this doesn't tell me anything, and deleting the error log also doesn't help.
Thank you.
Thomas
Thomas_Alt Blaumann
28-11-2012, 8:50 Subject: Parking Assist T5 |
Hello everyone,
Bitte gib den Text, den du übersetzt haben möchtest.
The aftermarket trailer hitch was not "dialog-capable" but was encoded in the gateway. Therefore, the parking brake waited for a response from the trailer hitch to determine if a trailer was attached, and since no response was received, it entered the error mode.
Trailer hitch disconnected and everything worked again (except for the beeping when the trailer is attached).
One can't have everything, after all.
Greetings
Thomas
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
28-11-2012, 10:13 Subject: Parking Assist T5 |
Thank you!
Profile PM WWW Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7823 Karma: +1098 / -0 Location: BAR
28-11-2012, 10:24 Subject: Parking Assist T5 |
Can't I manually inform the device that I'm taking a trip with a trailer, thereby disabling the sensors? Our (work) T5 with a trailer coupling has received a corresponding switch, which, according to the (internal) operating manual, should be pressed after the trailer is attached. Automobile Zeitzeugen: |SUZUKI Swift Sport (2008)| |Smart 450 (2002)| |Honda CB 125 F (2018)|
