Passat 3c Wagon: Speedometer "fluctuates"
anywhere
Post25-12-2011, 2:29    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Hi everyone,
Having all this expertise here, I've gained some valuable experience... icon_wink.gif
I'm experiencing a problem where the tachometer on my Passat CR fluctuates when I'm driving at a constant speed. This applies regardless of whether the cruise control is active or you are manually controlling the gas pedal – and it is speed-independent.
Usually, it's sinusoidal, meaning I'm usually maintaining a constant speed of 100, and the speedometer fluctuates between 100 and 103. Occasionally, there are also minor tremors, however, I don't usually observe them often, as I generally pay attention to traffic...
On the internet, I found a similar problem in the Scirocco forum, unfortunately without a solution other than "isso".
I pointed out the error to VW, and they replaced the KI with a different one (I don't know if that's true, but it's mentioned in the DISS), and the error was reproducible.
Now I've read that the sensors should be located in the gearbox: is it worth replacing it? Do you perhaps have any more ideas about what I could try?
Videos where you can tell what I mean:
Edit Admin: The attachment function is designed to be used.
A very Merry Christmas, thank you very much, and best wishes,
Marco
Ross-Tech-Support
Post25-12-2011, 22:00    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Diagnosis log/Vehicle scan?
It would surprise me if the sensor was located in the gearbox, as all reasonably current models generate the signal based on the wheel speed sensors of the ABS/ESP.
anywhere
Post26-12-2011, 19:13    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Hi Sebastian,
okay, it's also possible that I have misunderstood, as I haven't yet progressed to Layer 1 (cable - corresponding to the OSI model).
@Admin:
Sorry, from now on I will upload all videos directly here. My idea was that I didn't want to overload your server...
Okay, hier ist die Übersetzung:
So, nochmal alles zusammengefasst.
Marco
Passat 3c Wagon: Speedometer "fluctuates" - Tachonadel-schwankt-Passat-3C.mp4
 Passat 3C Kombiinstrument: Tachonadel "schwankt" immer noch
 File size:  9.63 MB
 Viewed:  4684 times
Passat 3c Wagon: Speedometer "fluctuates" - 20111222_193340.mp4
 File size:  17.27 MB
 Viewed:  5572 times
Log-WVWZZZ3CZ9E12xxxx.txt
 Rahmenbedingungen schwankende Tachonadel Passat 3C
 File name:  Log-WVWZZZ3CZ9E12xxxx.txt
 File size:  15.07 KB
 Downloaded:  1069 times
Post26-12-2011, 19:45    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Hello Marco,
Thank you for the videos/the scan! Don't worry, the server won't be "filled up" like this, but the files embedded in the topic will ensure that it's still recognizable even in a year.
Because, in the past, it has unfortunately been shown that files linked to from external sources, for example, on file-sharing platforms or elsewhere, tend to disappear over time.
As a result, one obtains a text related to images/videos or logs that are no longer available. -> Unfortunately, this is useless. Therefore, it's better like this.
Unfortunately, I don't really have any ideas for creating a "cursor wiggling" effect, as this is a new effect for me.
Why don't you check the vehicle speed, you can also compare the speed in the engine control unit (data block 6) and the speed in the data blocks of the instrument cluster.
If the values are not fluctuating, it must inevitably be due to the software of the instrument panel (update planned?).
Best regards, Rainer
anywhere
Post28-12-2011, 2:45    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Hi Rainer,
Unfortunately, the MSG's log isn't looking too good: "However, the MSG seems to be calmer than the KI."
On the KI's log, you can see approximately constant RPMs between 30 and 55 seconds, with the speed fluctuating between 66 and 67.
I must also say that he has been swaying again, but not with the intensity that I am used to.
I will submit a log with a higher speed. I didn't feel like driving on the highway anymore, considering the advanced time...
Marco
LOG-17-1351-1691.csv
 Log Kombiinstrument
Log Kombiinstrument
 File name:  LOG-17-1351-1691.csv
 File size:  16.43 KB
 Downloaded:  614 times
LOG-01-006-030-002.csv
 Log Motorsteuergerät
 File name:  LOG-01-006-030-002.csv
 File size:  79.4 KB
 Downloaded:  633 times
Post28-12-2011, 14:52    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Hello Marco,
I think, considering the values, we can assume that the speed measurement is okay, and the problem is likely in the instrument cluster...
Post28-12-2011, 15:38    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
I have something in mind related to "will be fixed with an update".
... or am I mistaken?
ICeYmx
Registered VCDS User
Post28-12-2011, 17:22    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Do you understand, Martin? But there was no specific information, and as far as I know, no feedback either.
The old blue AI in the 3C hasn't fluctuated, and neither does my current 3C with the white AI. icon_rolleyes.gif I can add a scan if needed.
edit:
[code]Address 17: Control cabinet insert (J285) Label file: DRV\3C8-920-xxx-17.clb
Part Number: SW; 3C0 920 871 T HW: 3C0 920 871 T
Part: KOMBI H05 0110
Serial Number: 00000000000000
Encoding: 160D00
Operating Number: WSC 05314 115 00317
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
VCID: 35655F67945A6F3
No errors found.
anywhere
Post29-12-2011, 13:28    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Thank you for the answers, I also searched in the Passat forum, but I didn't find the information until I saw your hint...
Following procedure: My Passat went to VW Hamburg and was inspected there. According to the employee, no software update was made, as there was no update available (because they would always update the software first in such cases).
The car then went to a dealership in Gifhorn without further repair (as the dealer intended), and they re-entered the problem in the DISS - but did not further investigate it: not even a "Ba not traceable" like with the other things they didn't want to see.
On the invoice, it states: "Combination instrument checked" and "Combination instrument - cross-swap". Yesterday, I called the dealership again to inquire: Just now, I received a notification that they were unable to identify the issue, and if the problem reappears, I would have to bring the car back in. (Interestingly, during the repair, the service technician called me and said, "they would need to reconsider the KI" - so it was very clearly understood...)
Clearly, I am unable to reach a resolution through warranty, as the (dealer specified by the seller) generally finds very few defects*.
Are there any other approaches to solving this problem? I have read that there are different manufacturers of tachometers - does this also apply to the white one?
Ideally, I would of course have the 3c8 TFT-KI, but then my steering wheel would no longer function... Therefore, there is no option (especially since I can no longer see the point in constantly pouring more and more money into the car until it functions properly...).
Thank you and best regards,
Marco
* Another thread: Auxiliary heater - The battery at the rear is completely dead -> no warranty, as it is a wear and tear part and the battery functions according to its capacity. If it's only 6 minutes, that's bad luck...
Ross-Tech-Support
Post29-12-2011, 14:08    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Understanding the complaint is simple enough: activate the digital speedometer and display it. Then, while the needle is shaking, maintain a stable speed (if possible, using cruise control) and record a video (using a phone or camera, etc.). This will then clearly demonstrate the situation. In case of doubt, contact the TSC or, alternatively, take a test drive together with the customer service representative.
I cannot understand the statement about the update. As far as I know, there are no updates for these switchboard components, and SW 0110 is currently not available. The supplier is always Siemend/VDO in the 3C, identifiable by the abbreviation VDD in the extended identification and also in this case in the ASAM dataset.
DieselBär30x
Avatar-DieselBär30x
Hi Marco!
According to It seems the main problem lies with the "partner" service, therefore...
My tip:
Find a different, or more customer-oriented, car dealership and try your luck there again icon_rolleyes.gif
Best regards from Munich!
anywhere
silikon likes this.
Post30-12-2011, 3:14    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Hi everyone,
I had a phone call today with VW in Wolfsburg regarding all my problems.
Regarding the speedometer issue, we have concluded that I will escalate the matter to VW Hamburg, meaning that they will, in turn, contact TSC*. But things will only start happening in the new year - I will get in touch if I have any news.
Thank you all for the feedback!
Marco
* for those of us who aren't so tech-savvy: Technical Service Center - is a facility located in Wolfsburg, to which VW workshops can turn to solve "difficult" problems
anywhere
Post04-07-2012, 1:59    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
... since I can no longer edit the old post, here is the promised feedback.
There are no errors that can be found in the AI. The speed signal is perfectly constant, and another AI shows the exact same behavior.
That means there is no error and everything is fine. Another Passat exhibits a similar behavior, but not as pronounced as mine.
I'll leave it at that. . .
Georg-TDI
Post09-07-2012, 16:59    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
Hello Marco.
Thanks for the feedback.
On my Passat, the speedometer needle also wobbles.
I also have the white AI.
I don't mind it too much (after all, I'm only driving at speeds between 70-90 Km/h occasionally).
Your experience has shown that you can also be let down by the friendly company...
Greetings,
Georg
anywhere
Post08-12-2012, 11:59    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
I would like to bring this back to light for future generations.
I have now installed a new KI (3C8920880G), and the problem is now completely resolved.
So, that's the old AI.
Marco
Post08-12-2012, 12:01    Subject: Passat 3c Wagon: Speedometer "fluctuates" Quote
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 Battery Problem: Weak Battery Warning Light Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Passat 3C: Raise Ride Height with Auto Leveling On-Board Diagnostics (OBD)
No new posts Passat 3B AFN - "Power from below" is missing (long engine Diesel Engine Technology
