A6 4F, Year 2009, Rear Axle Oil Change
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post09-01-2013, 19:53    Subject: A6 4F, Year 2009, Rear Axle Oil Change Quote
I was asked today if I could change the rear axle oil for a friend's A6 4F 3.0TDI Quattro.
I thought that Audi had come up with something new, but after reading some posts online, I'm still not entirely sure.
According to what I've found, it's the same opening for both draining and filling. It reminds me somehow of the Golf 4 with Haldex, where you also had to "press in" the oil.
Is there perhaps a cartridge available for purchase that allows you to do this, or is this method already implemented here?
Hopefully, someone here has already gained some experience.
Greetings
Post09-01-2013, 20:17    Subject: A6 4F, Year 2009, Rear Axle Oil Change Quote
As far as I remember, there should be a fill screw in the area of the drive shaft, and a drain screw from below.
klahaui
Avatar-klahaui
Post10-01-2013, 17:50    Subject: A6 4F, Year 2009, Rear Axle Oil Change Quote
A good approach would be to take a look at that when I eventually get the vehicle.
Thank you very much.
No new posts Glühkerzen wechseln 2.0l PD TDI 16V Troubleshooting & Guides
No new posts Zündanlassschalter beim Golf3 wechseln Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Passat 2009 power loss Diesel Engine Technology
This topic is locked, you cannot edit or reply. Passat 3C Bj. 2009 - EPB Problem Transmission, Chassis, Body & Interior
No new posts Unclear fuse assignment for VW [Touran 1T, 04.2009] Dieselschrauber Bar
No new posts Labelfile für STG09 für GOLF GTI BJ 2009 On-Board Diagnostics (OBD)
