Coding the service interval display on Golf III (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post22-05-2002, 16:30    Subject: Coding the service interval display on Golf III Quote
The service interval display can be coded according to the following list. This is, for example, necessary after a change of instruments.
When the ignition is switched on, press and hold the button below the speed indicator.
By pressing the minute button on the digital clock or the button for setting the analog clock, the setting mode is activated.
On the distance indicator, the text "OEL1.S." appears.
By pressing the button below the speed indicator again, the following display appears sequentially: OEL2.S, IN01.S, IN02.S.
Explanation of Service Events
Oil1.S Mileage Counter for Engine Oil Change
Oil 2.S Mileage Counter for Engine Oil Change
IN01.S Inspection Service Counter every 12 months
IN02.S Mileage Counter for Inspection Service every 30,000 km
Note:
The ".S" stands for Set Mode.
By pressing the button to set the analog clock or the minute button of the digital clock, the remaining distance or time until the service event is displayed.
By pressing the button again, the distance counter will be reset in increments of 500km and the time counter will be reset in increments of 1 month. After the smallest value, the largest value appears again.
If the ignition is switched off or the engine is started, the set mode will be exited.
Tschüss
Michael II
Ratings - Coding the service interval display on Golf III
No new posts Resetting the service interval display on a Volkswagen Go... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error light, indication of defective lamps General Tips
No new posts Service Interval Display: How to Reset Diesel Engine Technology
No new posts TDI Golf 3: Unlock/Code GRA Functionality On-Board Diagnostics (OBD)
No new posts AHK Coding On-Board Diagnostics (OBD)
No new posts Reset Service Interval with VAG-COM 0.81? Diesel Engine Technology
