WFS Function: Quick Question & Explanation
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +590 / -0   Thank you, like it!
Post23-01-2013, 20:30    Subject: WFS Function: Quick Question & Explanation Quote
Hello!
Sure, here's the translation:
"Short question:"
Once the immobilizer has been deactivated by the ignition key transponder,
Will it remain free as long as the ignition is on?
Or, to put it another way:
If the transponder in the key or the reading coil/wiring fails while driving, will the car stop working?
Translated on 17-08-2026, 4:08.
Post23-01-2013, 20:45    Subject: WFS Function: Quick Question & Explanation Quote
The WFS (presumably a specific function or system) is only active during the startup process, at least in the Bosch MSA12/EDC15/16/17 engine control units that I am familiar with.
Translated on 17-08-2026, 4:09.
Post23-01-2013, 20:59    Subject: WFS Function: Quick Question & Explanation Quote
Hi!
Thank you, Rainer.
(quickly, on a phone hotline)
Translated on 17-08-2026, 4:10.
Post23-01-2013, 23:48    Subject: WFS Function: Quick Question & Explanation Quote
dieselschrauber wrote:
The WFS (Write Flash System) is only active during the startup process, at least in the Bosch MSA12/EDC15/16/17 engine control units that I am familiar with.
Exactly. Therefore, you can safely bypass the ignition switch, remove the key, and the engine will continue to run.
Can be used to...
A) to steal the box, or...
B) Similar to how I keep the engine running in the summer (for the air conditioning). I implemented this using a small microcontroller circuit (activation with a button, deactivation either with another button or when the handbrake light goes out - so that no one can steal the car). It's not exactly environmentally friendly, but the police have used similar systems to prevent the batteries from being drained by rooftop discos.
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 17-08-2026, 4:11.
No new posts Quantity setting device and control path generator: Function Technical Articles
No new posts Exhaust gas recirculation: function and problem areas Technical Articles
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Plant Oil Additives: Quick Question Diesel Engine Technology
No new posts Audi A6 Error Code 550: Quick Question? Diesel Engine Technology
No new posts Frage zu Bau/Funktion digit. LDA bei Anleitungen Diesel Engine Technology
No new posts AGR Function: Questions and Answers Diesel Engine Technology
