AFN Engine: Head Gasket, Connecting Rod Issues?
vwSchrauber
Post01-02-2013, 8:28    Subject: AFN Engine: Head Gasket, Connecting Rod Issues? Quote
bored out to 81mm, fits in the AFN engine, compatible with pistons from various five-cylinder engines. My question is: is there a suitable head gasket available for this?
The 2.0 2V PD (BMM) version doesn't fit. It might fit the newer VE TDI engine without the auxiliary shaft, which has a flat oil return channel on the front.
Translated on 31-10-2026, 16:54.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post01-02-2013, 21:11    Subject: AFN Engine: Head Gasket, Connecting Rod Issues? Quote
The only person who comes to mind is the engine repair specialist, who might be able to order something like that.
It's normally used when the "last" excess material is being drilled away. In the aftermarket, standard seals of varying thicknesses are usually the only ones available.
Mpire.
Translated on 31-10-2026, 16:55.
Karma: +1359 / -0   Thank you, like it!
Post01-02-2013, 21:21    Subject: AFN Engine: Head Gasket, Connecting Rod Issues? Quote
That leaves only one option: install it, measure the piston protrusion, and then, based on the engine block (RLF), determine the correct head gasket.
Does the piston have the correct valve clearance?
Sure, here's the translation:
"Best regards," or "Sincerely,".
Translated on 31-10-2026, 16:56.
vwSchrauber
Post04-02-2013, 11:10    Subject: AFN Engine: Head Gasket, Connecting Rod Issues? Quote
I found something suitable.
The AFN engine's cylinder bore is 81mm, which covers all possible oversize tolerances.
The 1.6L ZKD (cylinder head) for the Passat 3B has a 82.5mm bore, and everything fits except for 3 small water channels. The gasket thickness of 1.6mm also fits (three-hole design for the AFN engine).
The compression height of the R5 pistons is 45.75mm, which is the same as the 45.80mm for the 1.9 R4 pistons, so they are compatible.
In the second over-size stage, the AFN apparently has a diameter of 80.5mm, which means there's enough material to allow for an 81ee bore.
It is normally used when the "last" excess material is drilled away. In the aftermarket, only standard seals in different thicknesses are usually available.
I have a catalog in print form that includes nearly all off-highway engines, including industrial TDIs. I am currently comparing them icon_biggrin.gif.
Translated on 31-10-2026, 16:58.
vwSchrauber
Post06-02-2013, 16:10    Subject: AFN Engine: Head Gasket, Connecting Rod Issues? Quote
Does anyone know anything about the connecting rods? The piston pins fit the 1.9-liter connecting rods, but the pistons from the five-cylinder engine are about 40 grams heavier.
Do the five-cylinder engines have reinforced connecting rods? The VW part number is probably not the same, even if the connecting rods are identical...
Translated on 31-10-2026, 17:00.
No new posts Urgent Diesel Piston Needed Diesel Engine Technology
No new posts Connecting rod of a ship's diesel engine Diesel Engine Technology
No new posts OT Setting per Week OT Sensor Borehole Diesel Engine Technology
No new posts Oil Leak at AXR Bore Hole near AGR Valve Diesel Engine Technology
