fuerni
2007 Audi A3 Premium Support
03-06-2013, 14:13 Subject: Oil Spills LLK: Pipe to Hose Transition |
I also got to see my A3 from underneath today.
Observed slight oil contamination at the transition point between the pipe and the hose.
Is this oil mist, or is it a leak from the connection?
Is there any action required?
Car: Audi A3 quattro 125kw, Engine Code: BMN.
| Description: |
| Anschluß LLK am BMN Motor |
| File size: |
1.42 MB |
| Viewed: |
632 times |
| Description: |
| File size: |
1.28 MB |
| Viewed: |
409 times |
Translated on 29-08-2026, 11:20.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
03-06-2013, 14:37 Subject: Oil Spills LLK: Pipe to Hose Transition |
Check where it's coming from; it might be leaking from above. Otherwise, tighten the hose clamp.
Translated on 29-08-2026, 11:21.
Profile PM WWW Garage |
fuerni
03-06-2013, 16:25 Subject: Oil Spills LLK: Pipe to Hose Transition |
The oil is definitely coming from the connection. I've tightened the clamp for now and will continue to monitor it.
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
Profile PM Garage |
