Oil Spills LLK: Pipe to Hose Transition
fuerni
2007 Audi A3
Post03-06-2013, 15:13    Subject: Oil Spills LLK: Pipe to Hose Transition Quote
I also got to see my A3 from underneath today.
Observed slight oil contamination at the transition point between the pipe and the hose.
Is this oil mist, or is it a leak from the connection?
Is there any action required?
Car: Audi A3 quattro 125kw, Engine Code: BMN.
 Anschluß LLK am BMN Motor
 File size:  1.42 MB
 Viewed:  620 times
 File size:  1.28 MB
 Viewed:  399 times
Translated on 29-08-2026, 12:20.
Post03-06-2013, 15:37    Subject: Oil Spills LLK: Pipe to Hose Transition Quote
Check where it's coming from; it might be leaking from above. Otherwise, tighten the hose clamp.
Translated on 29-08-2026, 12:21.
fuerni
2007 Audi A3
Post03-06-2013, 17:25    Subject: Oil Spills LLK: Pipe to Hose Transition Quote
The oil is definitely coming from the connection. I've tightened the clamp for now and will continue to monitor it.
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
No new posts Shorter LL Paths: More Power, Pipes vs. Hoses? Diesel Engine Technology
No new posts Turbocharger Boost Hose: Connection & Oil Issues Diesel Engine Technology
No new posts Install Oxykat with Through Pipe Transmission, Chassis, Body & Interior
No new posts FSI Hose: What is this pipe for? Diesel Engine Technology
