chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
08-07-2013, 15:07 Subject: Replace T4 Dual Mass Flywheel |
Hello!
I have a T4 AJT 2.5 TDI, manufactured in 2000, with 380,000 kilometers on the clock, and the clutch is faulty.
Normally, I always replace the clutch along with the dual-mass flywheel (DMF).
I saw that Valeo offers a kit with a fixed flywheel.
"A timely alternative to ZMS" is what this sentence is called.
Has anyone ever tried this before? What experiences have you had with it?
Thank you very much!
A6 AFB
A6 BRE DPF
Translated on 29-09-2026, 9:35.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
08-07-2013, 15:50 Subject: Replace T4 Dual Mass Flywheel |
Quote: | | What experiences have you had with it? |
It will probably work, but there will likely be compromises in terms of comfort. This largely depends on individual expectations. The extent of these compromises remains to be seen...
Used search function: EMS or ZMS.
Translated on 29-09-2026, 9:36.
chli1976 Profi-Schrauber
09-07-2013, 7:38 Subject: Replace T4 Dual Mass Flywheel |
For 4-cylinder engines without a balance shaft (modul), you can use it without noticeable drawbacks. It's supposed to not work with engines that have a balance shaft, and it's rumored to cause noise, although I haven't tried it myself. I haven't tested it on 5-cylinder engines either.
VCDS
Translated on 29-09-2026, 9:37.
sebv6 Blaumann
2000 Volkswagen Passat  Free account, no CAN development support
09-07-2013, 12:19 Subject: Replace T4 Dual Mass Flywheel |
I've now installed two single-mass flywheel kits in a long-wheelbase TDI van (102 hp) and in an AJT pickup truck. It's a bit more noisy at idle than before. Starting the engine can be a little less comfortable. It's comparable to an older /8 200d. But driving is a dream! You really get a feel for the clutch. I would definitely install it again!
Passat TDI PD AWX 12/2000
Profile PM Garage |
roorback Blaumann
Joined: 12/22/2003 Posts: 374 Karma: +1 / -2 Location: kärnten/österreich
09-07-2013, 15:52 Subject: Replace T4 Dual Mass Flywheel |
Hi.
The AJT should be similar to the AEL, but with slightly less power. I also have the ZMS in my Volvos, and it had a problem once at 280,000 km, but the car had been producing 400 Nm of torque up to that point.
He then bought a used one, and it works perfectly.
I also left the ZMS on some other cars - my cars have 400-500 thousand kilometers (approximately 250-310 thousand miles) - it should still work.
Essentially, there are a few values for the ZMS (presumably a technical term), and you can actually measure these quite accurately using the equipment available, allowing you to determine its condition.
If the fat leaks out, the surface is damaged, or it's completely "gouged out," then a new one is obviously needed.
Translated on 29-09-2026, 9:39.
