Golf 4 Headlights: Replacement & Upgrade
windl
Post29-04-2003, 13:53    Subject: Golf 4 Headlights: Replacement & Upgrade Quote
Does anyone know if the headlight mounting brackets are compatible between the Golf IV headlights?
'Can you replace them, meaning if any are broken, can you replace them with ones from a headlight that has good mounts? Just the mounts!'
Translated on 25-09-2026, 1:13.
kenny
Post29-04-2003, 14:52    Subject: Golf 4 Headlights: Replacement & Upgrade Quote
There's a repair kit available, I'm not sure if it's directly from VW or from somewhere else. I also had the suspension break once.
Translated on 25-09-2026, 1:14.
windl
Post29-04-2003, 14:54    Subject: Golf 4 Headlights: Replacement & Upgrade Quote
Can the brackets be swapped, meaning can you move them from one headlight to the other? Or what does the repair kit look like? Does it include new brackets, or is it just an adhesive solution?
DaBibo
Post29-04-2003, 16:14    Subject: SEO-Optimized Title Translation: "Best German Translation Services | Fast & Accurate" Quote
Part number 1J0 998 225, screw-on type, if I recall correctly.
Translated on 25-09-2026, 1:15.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Headlight Installation Guide Transmission, Chassis, Body & Interior
No new posts DEPO Headlights: Buy Online & Save! Diesel Engine Technology
No new posts Spannung Frontscheinwerfer Transmission, Chassis, Body & Interior
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
