Replace Single Fan with Dual Fan
Post08-08-2013, 19:23    Subject: Replace Single Fan with Dual Fan Quote
Hi.
Our BLS only has a single fan installed.
1K0 121 207 AS
1K0 121 205 AA
It's making a noisy racket because the fan is probably not properly balanced anymore.
Mechanically, the 1K0 121 207 T double fan should fit.
It was installed with AHK/automatic functions in the BLS.
Besides, you can find it at a good price on eBay right now.
Does anyone know if it can be easily replaced with an electric version?
Unplug the connector, remove four screws, and you're done?
Translated on 27-09-2026, 17:25.
Karma: +646 / -0   Thank you, like it!
Post14-08-2013, 15:42    Subject: Replace Single Fan with Dual Fan Quote
Let's compare the plugs here:
http://www.teilesuche24.de/hs/luefter-motorkuehlung-70455440?c=100337
with what you have on your car.
Translated on 27-09-2026, 17:26.
Post14-08-2013, 18:54    Subject: Replace Single Fan with Dual Fan Quote
Yes.
It looks like the plug is the right type.
I believe it's more likely a difference in the fan motors/ECUs.
And for that, one would need to know the tuition fees of the programs being offered.
Most of the time, only the part numbers for the fan modules (which are actually always 1K0 121 207 T) are listed.
 File size:  83.46 KB
 Viewed:  1332 times
Post15-08-2013, 9:59    Subject: Fan Upgrade: Single vs. Dual Fan Replacement Quote
dieselmartin wrote:
Does anyone know if it can be easily replaced with an electric one?
Hi Martin,
I don't know. But I would be very surprised if VW used different pin configurations or different protocols/commands for the fan. Therefore, I would suggest trying it out if you can get it cheaply.
Greetings.
Guste.
Translated on 27-09-2026, 17:27.
Post15-08-2013, 10:56    Subject: Replace Single Fan with Dual Fan Quote
I once asked the auctioneer about the noise level of the fans.
Because VW uses different fans depending on the engine type.
I think I'm on the safe side with the low-waste heat BLS system.
Alternatively, I was thinking about removing the simple fan and trying to balance it. Perhaps I would then be able to see where a weight is missing.
If I can't easily remove it, I'll have to wait for the next crash icon_twisted.gif before I can get the front back into a serviceable condition.
Unfortunately, the Passat is getting louder with real problems (control arm bushings, xenon shutter), so the humming fan in the Golf is taking a bit of a backseat.
Translated on 27-09-2026, 17:29.
Post15-08-2013, 16:07    Subject: Replace Single Fan with Dual Fan Quote
SO.
The simple exhaust fan vents from the top, without requiring much modification.
- Intake located between the crossmember and the air filter housing.
- Removing LuFiKa makes it more pleasant.
- Remove the soundproofing underlayment so that the fan can be rotated far enough.
Apparently, he never used weights.
It seems like having the quiet dual fan is purely a matter of comfort.
Or, the simpler one has a hidden defect that isn't noticeable when turning it by hand.
Translated on 27-09-2026, 17:30.
Post15-08-2013, 20:33    Subject: Replace Single Fan with Dual Fan Quote
Here, you can hear the strong humming sound, which the fan also transmits as vibrations to the body of the car:
Replace Single Fan with Dual Fan - EinfachBrumm.flv
 Brummender Kühlerlüfter Golf 5.
 File size:  5.04 MB
 Viewed:  518 times
Translated on 27-09-2026, 17:31.
Post15-08-2013, 20:52    Subject: Replace Single Fan with Dual Fan Quote
Does the propeller show any imprint or rust marks from a potentially corroded counterweight? If so, this indicates imbalance, which causes vibrations. The higher the speed, the more intense the vibrations will be.
Translated on 27-09-2026, 17:32.
Post15-08-2013, 21:02    Subject: Replace Single Fan with Dual Fan Quote
It sounds almost like a faulty alternator bearing. Are you sure the bearing is still in good condition?
Even at half speed, it sounds incredibly loud.
Post15-08-2013, 21:11    Subject: Replace Single Fan with Dual Fan Quote
I thoroughly inspected the entire propeller and cleaned it.
Not a trace of a lost counterweight.
When you turn it manually, you can hear a slight humming sound.
The bearing is otherwise completely free of any snags or play, so it is not fixed or seized in any areas.
That's what surprises me the most.
Translated on 27-09-2026, 17:33.
Post15-08-2013, 21:29    Subject: Replace Single Fan with Dual Fan Quote
Perhaps the propeller is rubbing against the housing under load.
Post16-08-2013, 9:09    Subject: Replace Single Fan with Dual Fan Quote
T3Surfer wrote:
Perhaps the propeller is rubbing against the housing under load?
I cannot absolutely rule that out, because I wasn't directly involved, icon_wink.gif
"However, since it moves a significant amount of air, it will at most be pulled away from the casing (as you can see in the video, it even moves forward)."
And there are no signs of grinding on the radiator.
 Kühler Golf 5
 File size:  160.8 KB
 Viewed:  1615 times
Translated on 27-09-2026, 17:34.
Post16-08-2013, 18:16    Subject: Replace Single Fan with Dual Fan Quote
Too bad I can't "feel" the video, but don't stop listening!
Perhaps a slight bearing defect that only becomes "audible" at high speeds; does the noise change when you move it back and forth? Similar to how a developing wheel bearing issue might sound when you steer left and right at around 60-110 km/h?
Translated on 27-09-2026, 17:35.
servusssss
Post18-08-2013, 13:53    Subject: Replace Single Fan with Dual Fan Quote
Hello Dieselmartin,
I also had problems with the fan in my Audi. Initially, the bearing made noises, similar to a faulty alternator clutch.
After about 3 weeks, the fan was completely broken.
Chips from the storage area have gotten into the winding.
At the icon_biggrin.gif, we had never had a fan that was defective.
New fan installed, and it's been quiet ever since.
SG.
Translated on 27-09-2026, 17:36.
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Should I switch from AGM to EFB? Electrical Systems, Vehicle Electronics, Multimedia
No new posts MFA for FIS swap On-Board Diagnostics (OBD)
No new posts Replacing the 8V particulate filter with the 16V catalyti... Diesel Engine Technology
No new posts Exchange Old MFA/BC for New? Transmission, Chassis, Body & Interior
