DPF Ash Reset for BMW 330d with Bavarian Technic
felix
Avatar-felix
Post20-09-2013, 14:43    Subject: DPF Ash Reset for BMW 330d with Bavarian Technic Quote
My DPF (Diesel Particulate Filter) in my facelifted E91 330d with 245 horsepower has already accumulated 28 grams of ash.
This already leads to some performance loss.
Now I would like to clean it, but first I need to regenerate it and then reset the ash content value.
Does that work with Bavarian Technic?
I couldn't find anything about it in either the wiki or the program itself.
Or is the machine actually smart enough to recognize that the filter is clean based on the lower back pressure?
Gruß Felix
E91 330d, 1/2009
Translated on 13-08-2026, 22:26.
Post20-09-2013, 14:48    Subject: DPF Ash Reset for BMW 330d with Bavarian Technic Quote
I haven't found anything about it either in the wiki or in the program.
Or is the box clever enough to recognize that the filter is clean based on the lower back pressure?
Good question. As far as I know, it's not currently possible, at least not in the same way as with VAG.
Does anyone know how this actually works in practice, for example, when replacing a DPF (Diesel Particulate Filter)?
Translated on 13-08-2026, 22:28.
mullemaus
Post20-09-2013, 21:15    Subject: DPF Ash Reset for BMW 330d with Bavarian Technic Quote
Translated on 13-08-2026, 22:29.
No new posts HEX USB + CAN und Bavarian Technic On-Board Diagnostics (OBD)
No new posts T5 CAAD ash value accidentally set to 0 Diesel Engine Technology
No new posts Retrofit DPF (HJS brand), and engine oil with/without add... Diesel Engine Technology
No new posts Reset Service Indicator A3 MJ 97 Diesel Engine Technology
