gaspedaluser Guest
20-04-2003, 18:14 Subject: Question about optocouplers in adapter construction |
I used some of my free time during the holidays to build an adapter. Thank you to everyone who was involved in creating the instructions and other materials.
Okay, here's the translation:
'Now my question: there are no numbers 1-4 printed on my optocouplers!' How can I figure out which way to insert them into the etched plate without breaking anything?
I thought it was about the resistance of the diode, but it's infinite between every contact, probably because it's a type of LED.
Sorry if the question sounds silly, but I'm really only exploring this as a hobby.
Thank you, and have a wonderful Easter.
accelerator pedal
Translated on 04-07-2026, 8:09.
AndyO Guest
20-04-2003, 18:22 Subject: Optocoupler pinout |
If you're looking down at the PC 817 from above, the point you're referring to is the number 1. Then, you count clockwise. That means the 2 is on the same side, while the 4 is on the opposite side from the 1.
The rest can be easily reconstructed by comparing the layout and schematic diagram.
.1 4
2 3
Translated on 04-07-2026, 8:10.
20-04-2003, 18:26 Subject: Re: Question about optocouplers in adapter construction |
gaspedaluser wrote: | There are no numbers 1-4 printed on my optocouplers!? How can I figure out which way to insert them into the etched plate without breaking anything?
Hi.
Most often, there is a marking next to pin 1, such as a circular indentation.
Or, at the "head" end, between pin 1 and the highest pin (in this case, pin 4), there is a kind of notch.
The counting is done in a counter-clockwise direction (when viewed from above).
Translated on 04-07-2026, 8:12.
Profile PM Garage |
gaspedaluser Guest
20-04-2003, 19:00 Subject: Question about optocouplers in adapter construction |
Thank you for the quick responses.
Mine have a notch on the shorter side.
If you rotate it 90 degrees, there's a dot, and then it says ISP817. However, according to the counter-clockwise rule, the notches would connect to pins 1 and 2 instead of 1 and 4. According to the notch rule, 1 and 4 are adjacent, while 2 and 3 are on the opposite side.
It's strange, the spacing on Christian's etching plan would suggest that 1 and 2 (3 and 4) should be next to each other.
Is there anything else that might help with making a decision?
Translated on 04-07-2026, 8:13.
gaspedaluser Guest
20-04-2003, 19:03 Subject: Question about optocouplers in adapter construction |
Sure, here's the translation:
'Note:'
'For better understanding:'
I always look from above.
The step is located on the surface at the top left edge.
Translated on 04-07-2026, 8:14.
20-04-2003, 19:20 Subject: Question about optocouplers in adapter construction |
Hi.
I'll send you a datasheet for the PC817, etc.
That should answer all the questions...
Translated on 04-07-2026, 8:15.
Profile PM Garage |
gaspedaluser Guest
20-04-2003, 19:28 Subject: Question about optocouplers in adapter construction |
Hello Ulf,
My email address is [email protected].
Thank you and greetings.
AndyO Guest
21-04-2003, 11:07 Subject: Optocoupler pinout |
Okay, I'll try translating 'Kerbe von oben gesehen':
'Notch viewed from above.'
1. To the power of 4.
2_3
00schmu Guest
23-04-2003, 1:34 Subject: Question about optocouplers in adapter construction |
Optocouplers are for scaredy-cats  .
It can also be done without  .
Translated on 04-07-2026, 8:16.
23-04-2003, 16:53 Subject: Question about optocouplers in adapter construction |
00schmu wrote: | Optocouplers are for scaredy-cats.
It can also be done without  | .
. . . just like seatbelts and airbags
Profile PM Garage |
