Passive regeneration
Post17-06-2012, 20:25    Subject: Passive regeneration Quote
Hi.
Was wäre, wenn dies eine fast perfekte passive Regeneration gewesen wäre?
The 417 kilometers consisted of highway (140 km/h speed limit) and country roads.
My interpretation:
"A 'reg time' of 0.0 and 0 attempts means that the person is not participating."
2.6% means it's almost freshly registered.
"417 km" means that they haven't been actively registered for a very long time.
So, either he wasn't producing any soot, or it was operating within the load range where the DPF can self-clean. That is, hot enough for the soot to burn off, but not under such a heavy load that excessive amounts of soot are produced.
I need to check my Bosch manual.
Code:
Sonntag,17,Juni,2012,19:21:30:31600
VCDS Version: RKS 11.11.3
Datenstand: 20120406
                Adresse 01: Motor  (03G 906 018 EM)
19:21:07 Block 068: Partikelfilter (Abgaswerte II)
  2.6 %  Beladungs- koeffizient
  28.16  Aschemasse
  -10.0 %  Aschelernwert
19:21:07 Block 070: Partikelfilter (Regenerationsstatus II)
  00000000  Status 4 Regeneration
  0.0 s  Regenerations- zeit
  0.0  Erfolglose Regenerationen
  0.0  Erfolreiche Regenerationen
19:21:07 Block 073: Partikelfilter (Fahrzeugdaten)
  27.9 l  Verbrauch seit Regeneration
  417 km  Strecke seit Regeneration
  4 h  Zeit seit Regeneration
Translated on 21-07-2026, 19:35.
Post18-06-2012, 17:27    Subject: Passive regeneration Quote
Now, after driving just a few more kilometers, something happened:
Code:
Montag,18,Juni,2012,15:06:25:31600
15:06:13 Block 068: Partikelfilter (Abgaswerte II)
  3.4 %  Beladungs- koeffizient
  28.16  Aschemasse
15:06:13 Block 070: Partikelfilter (Regenerationsstatus II)
15:06:13 Block 073: Partikelfilter (Fahrzeugdaten)
  0.5 l  Verbrauch seit Regeneration
  4 km  Strecke seit Regeneration
  0 h  Zeit seit Regeneration
Translated on 21-07-2026, 19:37.
Post18-06-2012, 18:45    Subject: Passive regeneration Quote
Hello Martin,
Does the "mileage since regeneration" counter potentially reset to zero after a certain interval x?
Post18-06-2012, 21:37    Subject: Passive regeneration Quote
It is also possible that:
At distances of 4XX kilometers, a regular [event/activity] MUST start (that's how it usually works).
Those must be the 420 ones, because I didn't fill up the 450 ones today.
He sees 2.8% and thinks to himself, "okay, that's good," and resets all the regulator counters.
That's also fine, because even with an active registration rate of 40%, he would stop injecting at a value significantly above 0%.
All in all, it's wonderful – because it doesn't consume any additional power.
I had never seen such a finely crafted, passively "clean" filter before.
On the other hand, I drove a lot (250 km one way, and then 360 km back the next day) but kept my speed at a calm 140 km/h – after all, I had new tires on the back icon_wink.gif.
Translated on 21-07-2026, 19:39.
Benni
Post20-06-2012, 7:29    Subject: Passive regeneration Quote
It looks like you were in the correct window for a passive regeneration.
Generally, this process happens constantly and always removes some soot (!). I don't understand "passive regeneration" to mean that it can only reduce the filter's load from, for example, 40% to 3% based on driving style/profile.
Furthermore, from my experience with my old Passat, I know that active regeneration is always initiated, but it can only take a few seconds.
"I've noticed this more often while driving. When using cruise control at a constant speed of 100 to 120 km/h, there are sometimes brief jolts. The turbocharger audibly spools up, and then after 2 or 3 seconds, it stops again, as if saying 'it's going - it'll be alright'."
Translated on 21-07-2026, 19:41.
garth.brooks
Post26-10-2013, 18:32    Subject: Passive regeneration Quote
What do you understand by 'suitable window'?
My understanding is that regeneration begins at a certain ignition temperature.
That is to say, the faster it runs, the hotter it gets – at least as long as there is oxygen in the exhaust gases, which is usually the case with diesel engines.
'So, if I accelerate up a hill in 5th gear with full throttle for 2-3 minutes, it should ignite, and the subsequent 20 kilometers at around 150 km/h should be enough to burn off any excess fuel. Or am I right?'
Translated on 21-07-2026, 19:43.
No new posts Windshield Wiper Regeneration General Tips
No new posts 1.6l CR-TDI, frequent regeneration / Diesel particulate f... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF Regeneration Diesel Engine Technology
No new posts DPF Regeneration: Polo 1.6 TDI Issues Diesel Engine Technology
This topic is locked, you cannot edit or reply. Regeneration nach km Diesel Engine Technology
No new posts Labelfiles, DPF Regeneration und Aschemasseabgleich On-Board Diagnostics (OBD)
