Electric Window Regulator for Polo 6N2 (Solved)
New Topic 🔒 Locked 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
chriskross
Post11-11-2013, 20:14    Subject: Electric Window Regulator for Polo 6N2 (Solved) Quote
Hello!
Ich habe ein Problem beim Polo 6N2 Bj 2001 3tg. elektr. Power window, front.
The problem is that whenever I unlock the car using the driver's door, the window immediately opens a short distance, about 5cm. The same thing happens when I lock the car.
On the passenger side, it also goes down, but only later, after about 10 seconds, which is normal.
As soon as I bring the lock to the middle position, it stops.
The cable guides were broken, so I re-soldered them.
Could it be related to the lock itself, perhaps?
A6 AFB
A6 BRE DPF
Translated on 08-09-2026, 3:09.
Post11-11-2013, 21:08    Subject: Electric Window Regulator for Polo 6N2 (Solved) Quote
What does the error memory indicate? It's possible that a comfort control module or central locking module is already installed.
Please perform a complete error scan. Before that, please save the existing errors, clear them, and then operate the central locking system, window lifters, etc., to reproduce the error. After that, scan again and post the results.
If available, the individual functions should be testable via the measurement data blocks.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 08-09-2026, 3:11.
chriskross
Post12-11-2013, 8:43    Subject: Electric Window Regulator for Polo 6N2 (Solved) Quote
Unfortunately, the Polo does not have a comfort control unit icon_cry.gif.
Is there a way to disable the comfort function?
Vehicle Identification Number: License Plate: POLO 6N2
Mileage: 47180 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: XX (6N - VW Polo (1995 > 2002))
Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
Vehicle Identification Number: XXXXXXXXXXXXXXXXX
Mileage: 47180 km
Address 01: Engine Control Unit
Label file: None
Part number: 030 906 032 CK
Component: ME7.5.10 3628
Coding: 00031
Operating number: WSC 31414
VCID: 55A5D1ADAF2ECAB6975-5148
No error codes found.
Readiness: 0000 0000
Address 03: Brake Electronics
Label file: RKS\6X0-907-379.lbl
Part number: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Encoding: 05603
VCID: 43811FF551BA4406C91-4B14
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 A
Part: 2P AIRBAG VW5 03 0006
Encoding: 12880
VCID: 3565712D0F6EEAB6775-5148
2 error codes found:
00532 - Power supply voltage.
07-10 - Signal too weak - Sporadic.
01280 - Passenger airbag deactivated.
35-00 - -
Address 17: Control unit insert
Label file: RKS\6N0-920-xxx-17.lbl
Part number: 6N0 920 804 E.
Component: KOMBIINSTRUMENT BOO V12
Encoding: 00141
Operating number: WSC 00006
VCID: 306B4039F00CCF9E243-5164
"One error found:"
01039 - Coolant temperature sensor (G2).
64-10 - Currently not verifiable - Sporadic.
Address 19: Diagnostic interface
Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway <-> CAN.
Encoding: 00022
VCID: F0EB0039B08C0F9EE43-5164
Address 25: Immobilizer
Label file: RKS\6X0-953-257.lbl
Part number: 6X0 953 257.
Component: IMMO 0008
Encoding: 00001
Operating number: WSC 00000
VCID: FDF5290DF7DE72F67F5-4B14
XXXXXXXXXXXXXXXXX VWZ1Z0A1497534
End.
A6 AFB
A6 BRE DPF
Translated on 08-09-2026, 3:18.
chriskross
Post12-11-2013, 15:15    Subject: Electric Window Regulator for Polo 6N2 (Solved) Quote
The problem was likely with the window motor in the adjacent car; as soon as the lock was turned, it would activate.
I have now disconnected the two cables that ran directly from the lock to the FHM (front head module) gr/ws (green/white) and ge/ws (grey/white). Now, the comfort function no longer works for the driver, but who needs that in such an old car icon_smile.gif?
A6 AFB
A6 BRE DPF
Translated on 08-09-2026, 3:25.
Post12-11-2013, 15:40    Subject: Electric Window Regulator for Polo 6N2 (Solved) Quote
Thank you for the feedback icon_wink.gif.
The problem was probably caused by the neighbor's window lifter motor
Unfortunately, in this case, it is to be assumed icon_wink.gif.
Translated on 08-09-2026, 3:26.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Window Repair: Audi A4 (1999) - Fix Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Mit Funkfernbedienung die elektr. Fensterheber absenken On-Board Diagnostics (OBD)
No new posts Polo 9N window lifter On-Board Diagnostics (OBD)
No new posts Polo 9N3 Window Regulator BUS Issue? Electrical Systems, Vehicle Electronics, Multimedia
This topic is locked, you cannot edit or reply. Polo 9N3: Check fuel pump after timing belt change Diesel Engine Technology
