Resetting the service interval on an Audi A3 8P
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
chriskross
Post15-09-2011, 17:38    Subject: Resetting the service interval on an Audi A3 8P Quote
Today I worked on an A3 model year 2010 with a speedometer that had white LEDs. I was unable to reset the service interval reminder (SIA) using VCDS. Longlife.
Is there a solution for this? Or can that currently only be done by the icon_biggrin.gif?
A6 AFB
A6 BRE DPF
Post15-09-2011, 17:57    Subject: Resetting the service interval on an Audi A3 8P Quote
Okay, regarding my A3 8PA... it's icon_wink.gif most likely a case of misuse due to the user's unusual procedure.
"Bending" via the assistant:
1. Switch to flexible interval.
2. Flexible service reset.
chriskross
Post15-09-2011, 18:13    Subject: Resetting the service interval on an Audi A3 8P Quote
I put my service on hold.
Then, a long list appeared, and I selected "Service Reset - Longlife (Rest of the World)."
The adaptation channels were rewritten, and it also indicated that the service had been reset, but the "service due" light continued to illuminate.
Best, Chris.
Log-A3-WAUZZZ8P2AXXXXXXXX.txt
 File name:  Log-A3-WAUZZZ8P2AXXXXXXXX.txt
 File size:  7.05 KB
 Downloaded:  3160 times
A6 AFB
A6 BRE DPF
Post15-09-2011, 19:27    Subject: Audi A3 8PA service recall Quote
Normally, it is sufficient to select the correct entry for the service reset using VCDS-RKS, i.e., for a standard diesel model for the EU, select "Flexible Oil Service Reset (Longlife/Rest of World/Diesel)".
If the settings might be incorrect, first perform the "Change to flexible Intervals (Longlife/Diesel)" option.
Resetting the service interval on an Audi A3 8P - SRI_Audi_A3_VCDS.flv
 Service Reset mit VCDS-RKS am Beispiel Audi A3 2.0 TDI
 File size:  11.25 MB
 Viewed:  34018 times
 MFA mit weissem Display im Audi A3 8PA
 File size:  11.09 KB
 Viewed:  80561 times
chriskross
Post15-09-2011, 20:46    Subject: Resetting the service interval on an Audi A3 8P Quote
I will try again, thank you!!!
A6 AFB
A6 BRE DPF
Ross-Tech-Support
Post16-09-2011, 10:16    Subject: Resetting the service interval on an Audi A3 8P Quote
Please attach the SRI-Log.TXT file from the /VCDS-RKS/Debugs/ folder here before you continue searching blindly. Okay, at least we'll see the actual values, but it does indeed sound like a user error.
chriskross
Post16-09-2011, 11:48    Subject: Resetting the service interval on an Audi A3 8P Quote
Okay, please provide the text you would like me to translate from German to English.
SRILog.txt
 File name:  SRILog.txt
 File size:  59.43 KB
 Downloaded:  2220 times
A6 AFB
A6 BRE DPF
Ross-Tech-Support
Post16-09-2011, 12:02    Subject: Resetting the service interval on an Audi A3 8P Quote
What work was carried out?
Oil change? Inspection (based on time or mileage)?
chriskross
Post16-09-2011, 15:19    Subject: Resetting the service interval on an Audi A3 8P Quote
30,000 km service.
KM as of 31200.
A6 AFB
A6 BRE DPF
Post22-02-2013, 16:18    Subject: Resetting the service interval on an Audi A3 8P Quote
Thursday, September 15, 2011, 09:14:51
VCDS RKS 10.6.4: Reset maintenance interval display -- Data version: 20110418
Control unit part number: 8P0 920 932 D
Label file: 8P0-920-xxx-17-MY8.clb
Component: COMBINATION INSTRUMENT. VDO H03 0990, Coding: 0004128.
Process: Please select a function. -- 1/2
Channel | Description | Unit | Current Value Value | New Value
02 Service Reminder Status 2 ---
40 Distance covered since last inspection km x100 313 ---
41. Time since service: 466 days.
42. Distance (minimum) to service station: km x 100. 150. ---.
43. Distance (Maximum) to service station: km x 100, 300, ---.
44 Time (Maximum) until service: Days 730 ---
45. Oil quality: 2 (---)
47. Entry fee: 0 km x 100.
48. Thermal stress: 367 km x 100 (---).
49. Time (minimum) until service: 365 days.
50 Base value for mileage interval for oil change: km x100 150 ---
51 Base value for oil change interval Day(s) 365 ---
52. Base value for inspection route: km x 100 = 300. ---
53. Distance covered since last inspection: km x 100. 313. ---
54 Base time for inspection Day(s) 1095 ---
55 Time since last inspection Days 466 ---
56 Daily counter Day(s) 496 ---
Thursday, September 15, 2011, 09:15:24.
Process: Flexible Oil Service Reset (LongLife/Rest of World/Gasoline) -- 2/2
02 Service Reminder Status 2 0
42. Distance (minimum) to service station: km x 100. 150. 150.
43. Distance (Maximum) to Service Station: km x100. 300. 300.
44 Time (Maximum) until service Days 730 730
45. Oil quality: 2 (rating) 2 (rating)
49. Time (minimum) until service: Days 365 365.
53 Track length since inspection km x100 313 ---
55 Time since inspection Days 466 ---
The new values were successfully saved, service indicator reset complete!
Okay, I'm guessing it's the entry from the 15th. September is the relevant month.
Here as well, it can be seen that the time since the last inspection and the mileage since the last inspection have not been reset.
Success would have been achieved, for example, by performing the "Mileage-based Service Reset (Rest of World)" and "Time-based Service Reset (Rest of World & Great Britain)" procedures.
Thank you to RedR32 for pointing out the error regarding the engine/vehicle; the post was mistaken.
Post27-11-2013, 13:42    Subject: Resetting the service interval on an Audi A3 8P Quote
See also:
/viewtopic.php?t=27079&highlight=audi+a1+service
No new posts CNG service reset, gas tank Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Service Interval Display / Maintenance Indicator Technical Data
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Service Reset Instructions On-Board Diagnostics (OBD)
No new posts vag-com and service interval indicator Diesel Engine Technology
No new posts Regarding the variable service interval again Diesel Engine Technology
No new posts Porsche PoCOM Service Intervals On-Board Diagnostics (OBD)
