Webasto Diagnostic Adapter
Go to page: 1, 2, 3  Next
PowerSound3L
Post25-04-2004, 15:44    Subject: Webasto Diagnostic Adapter Quote
hi,
I want to use the VAGCOM adapter and the Webasto software to read out my Webasto Thermo Top E.
Unfortunately, it doesn't work with the adapter (which has 3 optocouplers and 3 potentiometers).
With Bosch, it worked immediately and within seconds using the original Webasto adapter and both my laptop and theirs. Unfortunately, it cost 17 euros.
Has anyone used a VAGCOM adapter to read out data from a Webasto unit?
if so, then with which adapter?
Is there a wiring diagram available for the original Webasto adapter anywhere?
greetings
Translated on 30-07-2026, 7:48.
christians
Post25-04-2004, 20:16    Subject: Webasto Diagnostic Adapter Quote
With Maik's adapter, it wasn't a problem. I'll try Ulf's adapter sometime in the next few days, if I have the chance.
Gruß Christian
Translated on 30-07-2026, 7:49.
PowerSound3L
Post25-04-2004, 20:27    Subject: Webasto Diagnostic Adapter Quote
hi,
Okay, I'll build the adapter and try it out when the Webasto unit is returned from Webasto.
While reading the diagnostic data with Bosch software, there was a really cool and revolutionary error message displayed:
'Flame detected due to fuel supply.'
Diagnosis from the Bosch technician:
Control unit defective!
Since the unit was only installed 2 months ago and was working properly (manufactured in 2003), the Bosch technician told me that a new control unit or even a completely new Webasto heater would be available under warranty.
And now it's already at Webasto.
greetings
Translated on 30-07-2026, 7:51.
Jan03
2010 Volkswagen Polo
Post25-04-2004, 20:50    Subject: Webasto Diagnostic Adapter Quote
@PowerSound3L
"I had the exact same problem with my ThermoTop C. And I received the exact same response from Bosch when I asked what could be causing it. HOWEVER, THAT WASN't THE PROBLEM. It was just the glow plug that was faulty, as it's also used as a flame sensor in both the ThermoTop E and C (due to low resistance, it detects a flame even when there isn't one). I replaced it with a used one, and everything started working again."
Your problems with the diagnosis are strange. I also connected my VAGCom adapter, and it worked immediately. The connection is even much more stable than when I connect the adapter to my MSG. icon_confused.gif
/Jan
Translated on 30-07-2026, 7:53.
christians
Post27-04-2004, 20:20    Subject: Webasto Diagnostic Adapter Quote
Today I briefly connected an optocoupler adapter, I think it was version 2.3 from Ulf, and couldn't get it to work. However, I didn't have time to experiment with the potentiometers.
Gruß Christian
Translated on 30-07-2026, 7:54.
PowerSound3L
Post05-05-2004, 21:08    Subject: Webasto Diagnostic Adapter Quote
hi,
Today, the Webasto heater came back (I had sent it in to Bosch for repair).
It seems it was indeed just the glow plug as described above. It looks like only the glow plug has been replaced. The connector now has the inscription '2/04,' which means February 2004, so it must have been replaced then.
It's working in the car again.
Although it was a part purchased from eBay and installed by myself without an installation stamp from a workshop, the repair was still covered under warranty.
In total, it cost me 17 euros for the diagnostic scan at Bosch and 7.50 euros for shipping.
greetings
Translated on 30-07-2026, 7:55.
Jan03
Post06-05-2004, 7:44    Subject: Webasto Diagnostic Adapter Quote
@PowerSound3L
"Why are you getting so worked up? You probably got a whole new burner too, because you can't buy the glow plug separately. That should be the part that wears out most quickly on the heater. Mine is starting to give out; it's smoking and doesn't have much power left. You won't need to replace it for at least the next few years."
best regards
January.
Translated on 30-07-2026, 7:57.
PowerSound3L
Post22-08-2005, 17:26    Subject: Webasto Diagnostic Adapter Quote
hi,
Okay, the MAIKs adapter works perfectly fine.
However, I built a minimal version, just the K-line without the potentiometers and LEDs.
greetings
Translated on 30-07-2026, 7:58.
vagtuning
Post19-11-2005, 20:16    Subject: Webasto Diagnostic Adapter Quote
Has anyone ever tried using a large, original HEX-CAN USB interface with this software? Does it work with that type of interface, or is it only designed for serial connections?
Ross-Tech-Support
Post20-11-2005, 5:22    Subject: Webasto Diagnostic Adapter Quote
vagtuning wrote:
Has anyone ever tried using a large, original HEX-CAN USB interface with this software to see if it works properly?
It should generally work as well, especially if it functions with a simple or basic interface.
vagtuning wrote:
Or is this only designed for serial use?
Translated on 30-07-2026, 7:59.
VIP
Post02-01-2006, 13:55    Subject: Maik's Adapters: High-Quality & Reliable Quote
I've tried using several different ISO adapters to read data from my Thermo Top C.
hi,
greetings
I'm new to this forum and just starting to learn about things like 'Maik's adapter' and 'Jeff's interface.'
Could you please clarify something for me?
From what I've gathered, it only works with a specific setup.
Why? I don't know...
A schematic diagram or assembly instructions would be helpful.
'Thank you in advance!'
'Best regards,' or 'Sincerely,' (depending on the context).
Tom.
Translated on 30-07-2026, 8:01.
wolfi_b
Post02-01-2006, 14:16    Subject: Webasto Diagnostic Adapter Quote
Take a look inside.
I am using version 2.4 of Ulf. However, it only works for me with the DOS version (which has a much smaller feature set and no logs, etc.).
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 30-07-2026, 8:03.
VIP
Post02-01-2006, 18:57    Subject: Maik's Adapters: Still the Best Choice Quote
hey!
Thanks for your reply!
I was on the website and read everything again.
I couldn't find any information about an adapter from Maik.
I would also like to know what the differences are.
It provides the same functionality as a conventional ISO adapter.
It's really tedious to install Thermo Test Software 2.07 on Windows 98.
Getting it to run and then also dealing with the adapter problems.
Thank you in advance for your help!
Tom.
Translated on 30-07-2026, 8:04.
awo_atze
Post26-01-2006, 21:07    Subject: Webasto Heater Diagnostics: Troubleshooting & Repair Quote
Hello PowerSound3L,
Even though an explanation might now be obsolete, the reasoning seems quite simple to me:
It seems like you are using a USB adapter.
The problem is that the TT device from Webasto communicates with standard automotive K-line devices using the standard baud rate (the speed at which data is transmitted), according to the ISO standard (I won't go into detail here).
This baud rate cannot be generated using the standard rates used by USB devices. This means it deviates slightly, which prevents communication from occurring.
While Webasto also offers a USB adapter, it generates the baud rate itself.
Either your PC has an RS232 interface, in which case you can build the interface described here (it doesn't require anything special), or you can purchase the Webasto adapter, but that is not exactly cheap.
Commonly used USB to RS232 converters also do not work for the reason mentioned above!
However, there are no issues with the newly developed Webasto heaters, which are referred to as "W-bus" devices in the device selection.
Hope I was able to help you.
Best regards, Atze.
Translated on 30-07-2026, 8:07.
Post05-01-2008, 23:05    Subject: Webasto Diagnostic Adapter Quote
...or use this instead:
[Edit: http://shop.dieselschrauber.de/product_info.php/products_id/59 is no longer current. Diagnosis is possible via the K-line and professional system: http://shop.dieselschrauber.de/index.php/cPath/23]
Translated on 30-07-2026, 8:09.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post23-09-2009, 8:50    Subject: Webasto Diagnostic Adapter Quote
Does the Webasto software also work with the VAG-COM/OBD2 diagnostic professional system KKL+CAN?
"If so, which connector (OBD 2x1) should the yellow wire from the Webasto be connected to? Should it be connected to the black or gray one?"
B.Eng (FH) u. KFZ Meister
Translated on 30-07-2026, 8:10.
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts [Poll] OBD2 Adapter: Diagnose Tool for Cars Diesel Engine Technology
No new posts Diagnostic adapter Diesel Engine Technology
No new posts Diagnostic Adapter V3.1 Diesel Engine Technology
No new posts Diagnosis adapter On-Board Diagnostics (OBD)
